Logitech USB Headset H540
Quicklinx: 8DP9WS00 Mfr#: 981-000480
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Hurry, only 3 left in stock!
£40.65 ex VAT
£48.78 inc VAT
It is a high-quality, high-performance headset that brings your PC calls and music to life. Enjoy volume and bass level control, as well as the ability to instantly mute the mic - all at your fingertips and the soft leatherette padded headband and earcups allow you to talk or listen in comfort, for hours on end.
Soft leatherette padding is easy on your ears - especially when you're listening to music or chatting for hours. Worried about the fit? Don't be. The padding on the headband ensures a fit that molds comfortably to the contours of your head.
  • HIGH-DEFINITION SOUND QUALITY
    Laser-tuned drivers and built-in equalizer provide rich, digital audio for full immersion in music, games and calls. This plug-and-play headset can be used with any PC or Mac computer without the need to install software
  • NOISE CANCELING MIC
    Minimizes unwanted background noise for clear conversations. Right-sided mic can be conveniently positioned for better voice capture. Discreet boom can be tucked inside the headband and out of the way when you're not using it
  • ON-EAR CONTROLS
    Adjust the volume or mute your calls with simple on-ear controls located on the right ear cup. Confirm mute status with an easy-to-see light indicator on the headset cord
  • PADDED COMFORT
    Ultra-comfortable, adjustable design. Soft, padded leatherette headband and ear cups feel good even after hours of listening
  • USB CONNECTION
    USB provides easy plug-and-play operation. Simply plug the USB connector into your computer and instantly enjoy conversations, movies, or music in rich stereo sound
Logitech USB Headset H540 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Volume
Headset - wired
Recommended Use
Computer
Audio Output
On-ear binaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Microphone
Boom
Mono
Sensitivity
-40 dBV/Pascal
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Volume
Connector Type
USB (4 PIN USB Type A)
Cable Details
USB cable - 1.8 m
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
