Logitech Universal Keyboard Folio Case Bluetooth 3.0
Quicklinx: D139WS00 Mfr#: 920-008341
Device Type: Tablet, iPad
Type: Tablet Case
Device Screen Size: 9 - 10
Colour: Black/Grey
£45.44 ex VAT
£54.52 inc VAT
Universal Folio takes mobile computing to a new level. Now you can enjoy laptop-like typing anywhere you take your tablet. Universal Folio locks your 9-10 inch tablet at an optimal angle for typing and holds firm on any surface from a café table, a desk, or your lap. Its durable, spill-resistant shell protects your tablet during daily use.
  • Works with most 9-10 inch tablets
    A unique 4-point grip holds most 9-10 inch tablets securely and elegantly including iPad, Android and Windows tablets. The grip feature is so innovative, we've patented it. Universal Folio also features an integrated pencil holder to keep your stylus or pencil within easy reach as you swap in and out of tasks
  • Now your tablet can act like a laptop
    Enjoy hours of comfortable, flexible typing thanks to large well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Key travel of 2 mm provides the optimal depth for speed and comfort. Dedicated function and shortcuts keys for iOS, Android or Windows let you control the tablet without leaving the keyboard
  • Type on your desk or your blue jeans
    Simply open the case and start typing. Your tablet is locked in the perfect typing position and stays firmly in place even when typing on uneven surfaces like your lap
  • Solid build, long-lasting protection
    Universal Folio is designed according to Logitech's tough engineering standards. Built for years of everyday use, it features durable materials that hold up to constant use and occasional mishaps. A special strap securely closes your iPad and keeps it closed while being jostled around in your bag
  • Two-year battery life
    Ready when you need it, Universal Folio uses replaceable coin cell battery to power the keyboard. Thanks to a smart power management system, it lasts up to 2 years without a need to replace it
  • Easy setup, reliable connection
    Advanced Bluetooth 3.0 provides a reliable connection that won't drop between tablet and keyboard. Setup is easy-three simple steps take about a minute to complete
Logitech Universal - keyboard and folio case - QWERTY - UK Input Device
Keyboard and folio case
Bluetooth 3.0
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, search, screen lock, on/off switch
Protection
Water repellent
26.9 cm x 21.1 cm x 2.5 cm
465 g
1-year warranty
Bluetooth 3.0
Wireless
Hot Keys Function
QWERTY UK
Protection
Water repellent
26.9 cm
21.1 cm
2.5 cm
465 g
Carrying Case
Stylus holder, LED battery status indicator, secure corner grips
Microsoft Windows, Android, Apple iOS
CR2032
Installed Qty
2
Required Qty
2
Limited warranty - 1 year
Device Type: Tablet
Device Type: iPad
Type: Tablet Case
Colour: Black/Grey
Brand: Logitech
