Logitech Ultrathin T630 Touch Mouse
Quicklinx: 96Z1WS00 Mfr#: 910-003832
Made with a brushed metallic body and a silky-smooth touch surface, this mouse perfectly complements the sleek good looks of your ultrabook computer. Super thin and feather light, T630 slips nearly invisibly into a computer sleeve or even the pocket of your skinniest jeans. Your favorite mouse can go everywhere you do.
  • An ultra-portable pair
  • Touch your way around
    Experience Windows 8 navigation-effortlessly and confidently. T630 simplifies the touch experience with natural, intuitive gestures and makes you look good-and feel good-doing it
  • One mouse, multiple devices
    T630 connects to your devices using Bluetooth wireless technology. And our Easy-Switch technology makes it simple to toggle between your Ultrabook or desktop with the flip of a switch
  • Perfectly sized for a fingertip grip
    At just over 8 cm long and 5 cm wide , T630 relies on only your fingertips to operate. The precision sensor responds to even the slightest movements, and the touch surface registers nine different touch gestures
  • Quick charge
    Just one minute of charge time gives you enough power to keep working for another hour. If the charge runs low, simply plug it in. Your mouse charges over USB, so it's ready when you are
Logitech Ultrathin Touch Mouse T630 - mouse - Bluetooth
Mouse
Wireless - Bluetooth
USB charge cable
Microsoft Windows 7, Apple MacOS X 10.6.8 or later, Windows 8
3 years warranty
Mouse
Input Device
Wireless
Bluetooth
1 x USB - 4 pin USB Type A
USB charge cable
Limited warranty - 3 years
