UE BOOM is the 360º speaker that drops bold, immersive sound in every direction. Rage, riot, party and play the music you love, out loud. UE BOOM has a versatile, go anywhere shape that makes it as spontaneous as you - it brings the music, you bring the friends. Forget docking. With UE BOOM, you can switch songs, adjust volume and take phone calls from up to 50 feet away. Or grab a friend and take turns playing songs from two different devices. More friends crash the party? Wirelessly connect two UE BOOMs together in stereo via the UE BOOM app to instantly spread the sound and pump up the volume.
Portable design
Designed for portable use, the Logitech Ultimate Ears BOOM speaker is your go-to companion for music on-the-go. Its compact size and wireless connectivity allow for easy transport and setup anywhere you go. -
Waterproof build
With its waterproof protection, the Logitech Ultimate Ears BOOM speaker is engineered to withstand the elements. Whether it's a pool party or a rainy day, your music keeps playing without worry. -
High-quality sound
Experience rich, clear sound with a frequency response of 90 - 20,000 Hz. The integrated amplifier and active amplification type ensure that your music is heard loud and clear, with every note and beat perfectly captured.
- Ultimate Ears BOOM - Crystal Limited Edition - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Frequency Response
- 90 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - 90 - 20000 Hz - 4 Ohm - active
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 18 cm
- Dimensions - Diameter
- 6.5 cm
- 538 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Protection
- Waterproof
Speaker System
- Speaker Type
- Active
- 90 - 20000 Hz
- Max Output Level (Max SPL)
- 88 dB
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 15 m
- Controls
- Volume
- Additional Features
- 360° omni-directional
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 90 - 20000 Hz CFR - 4 Ohm - active
- Driver Details
- Speaker: 2 x full-range driver - 1.5" , Speaker: 2 x Passive Radiator - 2"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor, micro-USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 15 hour(s)
- Diameter
- 6.5 cm
- 18 cm
- 538 g
- Limited warranty - 2 years
