Logitech Ultimate Ears TripleFi 10 Earphones - Blue Metallic
Ultimate Ears TripleFi 10 Noise-Isolating Earphones
Quicklinx: 6JRMWS00 Mfr#: IF-P7PSA0005-04
Live in concert - TripleFi 10 earphones. Triple because it directs the low, mid and high frequencies to a separate speaker, a total of three in each ear (that's patented, you know). That means you'll hear every layer of sound, every nuance, every detail. A musician's breathing. Fingers sliding across guitar frets. Yes, you'll hear all that just as if the artist were performing live before you. It's the sonic equivalent of sitting in the world's best recording studio. How much clearer can we get?
TripleFi 10 - earphones
Earphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
Blue metallic
Headphones Form Factor
In-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 10 - 17000 Hz - Sensitivity 117 dB
Impedance
32 Ohm
20 g
Blue metallic
Recommended Use
Audio Output
In-ear binaural
Wired
Sound Output Mode
Stereo
Frequency Response
10 - 17000 Hz
Sensitivity
117 dB
Impedance
32 Ohm
Connector Type
Headphones (mini-phone stereo 3.5 mm)
Cable
Plated Connector
Gold
Hard case, 6.3 mm (1/4") stereo adapter, cleaning tool, headphone attenuator, 2 large cushions, 2 mid-size cushions, 2 small cushions
Cable Details
Headphones cable - 1.2 m
Resources
The following resources are available for the Logitech Ultimate Ears TripleFi 10 Earphones - Blue Metallic
