Fit, form and frequency - SuperFi 5vi earphones with voice capability. The unique top-fire speaker design gives you the flexibility to fit any situation you're in the moment you plug in. Wear them down to listen casually or on calls and over the ear while you're exercising. Either way, you're hearing just the sound of your highs and your lows and everything in between. Nothing but full, crisp and clean, well-rounded sound. That also means virtually all the outside noise is gone. Your neighbor on the bus won't hear you and you won't hear him. You're welcome.
For iPod®, iPhone®, MP3 players, and BlackBerry® devices with a standard 3.5mm jack.
- SUPER.Fi 5vi - headset
- Product Type
- Headset - wired
- Recommended Use
- Portable electronics
- Liquid silver
- Headphones Form Factor
- In-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 15 - 15000 Hz - Sensitivity 115 dB
- Impedance
- 13 Ohm
- 2-year warranty
- Product Type
- Headset - wired
- 14 g
- Liquid silver
- Recommended Use
Audio Output
- In-ear binaural
- Wired
- Sound Output Mode
- Stereo
- 15 - 15000 Hz
- Sensitivity
- 115 dB
- Impedance
- 13 Ohm
Microphone
- Wired
- Sensitivity
- -40 dBV/Pascal
- Connector Type
- Headset (mini-phone stereo 3.5 mm)
Cable
- Plated Connector
- Gold
- Included Accessories
- Hard case, 2 ear cushions
- Cable Details
- Headset cable - 1.2 m
- Limited warranty - 2 years
