Meet Ultimate Ears MEGABLAST, an incredibly powerful portable Wi-Fi/Bluetooth speaker with big, bassy 360° sound and hands-free voice control. Now with Amazon Alexa built-in, you and your crew can blast tunes, discover new music, order takeout, and more, with just the power of your voice. Do it all at home or on-the-go, even take calls without killing the music whenever connected to Wi-Fi or a mobile hotspot. MEGABLAST is waterproof, rugged, and stunning too - go from cocktail party to the pool party with confidence and style. Just say it to play it with MEGABLAST from Ultimate Ears.
Ultimate sound
Ultimate Ears MEGABLAST is insanely powerful. Blasting 360° intensely rich sound with stunning clarity and deep, heart-pounding bass, this Wi-Fi/Bluetooth speaker will bring your music to life in its full glory wherever you take it. -
Ultimate voice control
Ultimate Ears MEGABLAST comes with hands-free Amazon Alexa built right in. Just ask Alexa to blast tunes, discover new music, crank the volume, find new restaurants - or try any of Alexa's crazy skills. Use Alexa anywhere your speaker goes, all you need is Wi-Fi or a mobile hotspot. -
Seriously waterproof and virtually indestructible
Ultimate Ears MEGABLAST is rugged and seriously waterproof. Never worry about going easy on it. From the shower to the pool party, the summer BBQ to the winter slopes - your music will always be on point. -
The music never stops
Ultimate Ears MEGABLAST brings Wi-Fi to the portable speaker party and connects directly to the cloud. Enjoy fast, seamless music streaming and a bigger range to roam and dance. Anyone can DJ. And even take calls without stopping the music and killing the vibe."
- Ultimate Ears MEGABLAST - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Dustproof, waterproof, drop-proof
- Speaker Type
- Active
- Frequency Response
- 60 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- Intelligent Assistant
- Alexa - direct
- Green
- Battery
- Speaker battery rechargeable - Lithium Ion
- 23.7 cm
- Dimensions - Diameter
- 8.8 cm
- 1.2 kg
- 2-year warranty
- Product Type
- Microphone
- Protection
- Enclosure Colour
- Green
Speaker System
- Speaker Type
- Active
- 60 - 20000 Hz
- Max Output Level (Max SPL)
- 93 dB
- Amplifier
- Integrated
- Bluetooth, IEEE 802.11a/b/g/n
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 100 m
Internet of Things (IoT)
- Alexa
- Voice Control
- Direct
Speaker System Details
- Driver Details
- Speaker: 2 x woofer driver - 2.17" , Speaker: 2 x Passive Radiator - 3.35 x 1.97" , Speaker: 2 x tweeter driver - 0.98"
- Included Accessories
- Power adapter, micro-USB cable
- IP67
- Max Depth of Water Resistance
- 1 m
- Power Source
- Battery
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 16 hour(s)
- Diameter
- 8.8 cm
- 23.7 cm
- 1.2 kg
- Limited warranty - 2 years
