Logitech UE Boom 360 degree BT Speaker - Black
Quicklinx: BGXLWS00 Mfr#: 980-000735
UE BOOM is the 360ยบ speaker that drops bold, immersive sound in every direction. Rage, riot, party and play the music you love, out loud. UE BOOM has a versatile, go anywhere shape that makes it as spontaneous as you - it brings the music, you bring the friends. Forget docking. With UE BOOM, you can switch songs, adjust volume and take phone calls from up to 50 feet away. Or grab a friend and take turns playing songs from two different devices. More friends crash the party? Wirelessly connect two UE BOOMs together in stereo via the UE BOOM app to instantly spread the sound and pump up the volume.
  • Portable design
    Designed for portable use, the Logitech Ultimate Ears BOOM speaker is your go-to companion for music on-the-go. Its compact size and wireless connectivity allow for easy transport and setup anywhere you go.
  • Waterproof build
    With its waterproof protection, the Logitech Ultimate Ears BOOM speaker is engineered to withstand the elements. Whether it's a pool party or a rainy day, your music keeps playing without worry.
  • High-quality sound
    Experience rich, clear sound with a frequency response of 90 - 20,000 Hz. The integrated amplifier and active amplification type ensure that your music is heard loud and clear, with every note and beat perfectly captured.
Ultimate Ears BOOM - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Frequency Response
90 - 20000 Hz
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - 90 - 20000 Hz - active
Night black
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
18 cm
Dimensions - Diameter
6.5 cm
538 g
Hands-Free Function
Protection
Waterproof
Enclosure Colour
Night black
Speaker System
Speaker Type
Active
Frequency Response
90 - 20000 Hz
Max Output Level (Max SPL)
88 dB
Amplifier
Integrated
Bluetooth, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
Transmission Range
15 m
Controls
Volume
Additional Features
360° omni-directional
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 90 - 20000 Hz CFR - active
Driver Details
Speaker: 2 x full-range driver - 1.5" , Speaker: 2 x Passive Radiator - 2"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
AC power adaptor, micro-USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
15 hour(s)
Diameter
6.5 cm
18 cm
538 g
