Logitech TV Mount for Video Bars
Quicklinx: H1V5WS00 Mfr#: 952-000041
34 In Stock
£138.06 ex VAT
£165.67 inc VAT
Save space and clear the credenza by floating Rally Bar, Rally Bar Mini, or Rally camera below the display.
  • FLOATS BELOW DISPLAY
  • THE RIGHT ANGLE
    In rooms where above-display mounting makes sense, the 10° video bar tilt down adapter delivers a room-wide view with the right angle for video meetings
  • PERFECTLY PARALLEL
    Engineered for perfectionists. The built-in angle adjustment lets you precisely align the level of your video bar with the display
  • FLEXIBLE AND FLUSH
    Adjust mounting depth by up to 50 mm to fit a wide range of display thicknesses and wall standoffs
  • FITS MOST DISPLAYS
    With a versatile swing-arm design and industry standard VESA compatibility, TV Mount for Video Bars works with wall- and cart-mounted displays up to 248.92 cm in size (measured diagonally)
  • CLEAN CABLING
    Whether mounted above the display or below, thoughtful routing keeps cables securely connected and out of sight
Logitech TV Mount For Video Bars - camera mount
Camera mount
Placing / Mounting
Under-the-monitor mountable, above-the-monitor mountable
Package Content
Fasteners, 2 mounting plates
90 cm
Logitech Rally Bar + Tap IP, Rally Bar + Tap IP Graphite Bundle for Video Meeting Rooms, Rally Bar All-In-One Video Bar for Midsize Rooms, Rally Bar Mini + Tap IP, Rally Bar Mini All-In-One Video Bar for Small Rooms; Room Solution Large
Camera mount
Placing / Mounting
Package Content
90 cm
Logitech Rally, Rally Bar + Tap + Meet Compute for Google Meet Rooms, Rally Bar + Tap Cat5E Graphite Bundle for Microsoft Teams Rooms, Rally Bar + Tap IP, Rally Bar + Tap IP Graphite Bundle for Video Meeting Rooms, Rally Bar All-In-One Video Bar for Midsize Rooms, Rally Bar Mini + Tap IP, Rally Bar Mini All-In-One Video Bar for Small Rooms , Logitech Rally Bar, Bar + Tap Cat5E Graphite Bundle for Microsoft Teams Rooms, Bar Mini, Bar Mini Graphite + Tap + Meet Compute for Google Meet Rooms , Logitech Room Solution Large
Brand: Logitech
