Logitech TV Mount for MeetUP
Quicklinx: D38LWS00 Mfr#: 939-001498
Accessory Type: Camera mount
More than 50 In Stock
£74.49 ex VAT
£89.38 inc VAT
Logitech MeetUp is a premier ConferenceCam, designed for small conference rooms and huddle rooms. With a room-capturing, super-wide 120° field of view, MeetUp makes every seat at the table clearly visible. Motorized pan/tilt widens FOV even further: up to 175°. A low-distortion Logitech-engineered lens, Ultra HD 4K optics, and three camera presets deliver remarkable video quality and further enhance face-to-face collaboration.
MeetUp's integrated audio is optimized for huddle room acoustics and delivers an exceptional sound experience. Three horizontally-aimed beamforming mics and a custom-tuned speaker help ensure your meetings sound as great as they look. Humans have evolved to associate human voices with their visible images. MeetUp's front-of-room audio provides an intuitive and coherent listening experience. With a compact all-in-one design, that minimizes cable clutter, MeetUp is USB Plug-and-Play and simply works right out of the box with any video conferencing software application and cloud service - including the ones you already use.
  • SECURELY MOUNT LOGITECH MEETUP TO A TV OR MONITOR
    Logitech TV Mount for MeetUp securely holds the MeetUp ConferenceCam either above or below a flat-panel monitor and attaches to the industry-standard VESA mounting points available on most TVs and monitors
  • ATTACH ABOVE OR BELOW MONITORS
    The TV mount's unique design allows MeetUp to be mounted above or below a monitor. Attaching MeetUp below the TV tends to provide the most natural video experience, but this mount offers both options
  • WORKS WITH MOST FLAT-PANEL TVS
    Most TVs follow the VESA standard for locating mounting points on the back of TVs. The TV Mount for MeetUp features a swing arm design and multiple mounting holes to fit almost any flat-panel monitor
  • A SIZE FOR EVERY SCREEN
    Get the perfect fit for screens big and small. Choose TV Mount for displays up to 1397 mm (measured diagonally), or TV Mount XL for displays up to 2286 mm in size
Logitech TV MOUNT - camera mount
Camera mount
Placing / Mounting
On-the-monitor mountable
8.3 cm x 1.6 cm x 40 cm
280 g
Small Room Solution for Google Meet, for Microsoft Teams Rooms, for Zoom Rooms
Camera mount
Placing / Mounting
8.3 cm
1.6 cm
40 cm
280 g
Mounting Kit
Included
VESA interface support
Logitech Small Room Solution for Google Meet, for Microsoft Teams Rooms, for Zoom Rooms
Brand: Logitech
