Logitech Trackman Marble Mouse - Wired USB
Trackman® Marble®
Quicklinx: 5HYYWS00 Mfr#: 910-000808
Recommended Use: Leisure
Type: Trackball
Wired / Wireless: Wired
Colour: Red, Silver
Compatibility: Mac, PC
Hurry, only 2 left in stock!
£37.90 ex VAT
£45.48 inc VAT
Express delivery Delivered on Tuesday
The Logitech TrackMan Marble gives you superior comfort - for either hand. Ambidextrous design provides long-lasting comfort for right- and left-handed people. Convenient button controls let you easily move forward and backward when you're surfing the Web. Click the large buttons together and use the ball for auto-scrolling. Fingertip-based control enables fast, accurate cursor movements. Patented Marble optical technology ensures smooth tracking.
Left handed? Right handed? When you're working on your computer day and night, and you want more flexibility, the Logitech Trackman Marble will help increase your comfort level.
You'll enjoy all-day comfort with this ambidextrous trackball with convenient button controls.
Ambidextrous trackball design
A trackball design with a long, broad palm area and gentle curves keeps your hand comfortable and supported all day--whether you use your right or left hand.
Stable base
Your hand stays comfortable all day long with this stay-put design. Plus, it saves you space.
Buttons let you easily move forward and backward when you're surfing the Web.
You'll enjoy fast, accurate cursor movement with just a move of your finger.
Marble® optical technology
Our patented technology gives you smooth tracking on almost any surface so you can be productive wherever you work.
  • Ambidextrous trackball design
    A trackball design with a long, broad palm area and gentle curves keeps your hand comfortable and supported all day-whether you use your right or left hand
  • Stable base
  • Convenient button controls
  • Fingertip-based control
  • Marble optical technology
  • All-day comfort
    Whichever hand you use, this mouse keeps you comfortable and supported all day-and stays in one place
  • Back and forth
    Convenient Forward and Backward buttons help you get around the Web with ease
  • Marble marvel
    Fast, accurate control is right at your fingertip with smooth-tracking Marble optical technology
Logitech Trackman Marble - trackball - USB
Trackball
Wired - USB
Orientation
Right and left-handed
Movement Detection Technology
Optical
Buttons Qty
4
Logitech Marble optical technology
1 x USB cable - integrated
Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Works with Windows Vista
3-year warranty
Trackball
Orientation
Input Device
Wired
USB
Optical
Buttons Qty
4
1 x USB - 4 pin USB Type A
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM, USB port
Limited warranty - 3 years
Type: Trackball
Colour: Red
Colour: Silver
Compatibility: Mac
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
