The Logitech TrackMan Marble gives you superior comfort - for either hand. Ambidextrous design provides long-lasting comfort for right- and left-handed people. Convenient button controls let you easily move forward and backward when you're surfing the Web. Click the large buttons together and use the ball for auto-scrolling. Fingertip-based control enables fast, accurate cursor movements. Patented Marble optical technology ensures smooth tracking.
Left handed? Right handed? When you're working on your computer day and night, and you want more flexibility, the Logitech Trackman Marble will help increase your comfort level.
You'll enjoy all-day comfort with this ambidextrous trackball with convenient button controls.
Ambidextrous trackball design
A trackball design with a long, broad palm area and gentle curves keeps your hand comfortable and supported all day--whether you use your right or left hand.
Stable base
Your hand stays comfortable all day long with this stay-put design. Plus, it saves you space.
Buttons let you easily move forward and backward when you're surfing the Web.
You'll enjoy fast, accurate cursor movement with just a move of your finger.
Marble® optical technology
Our patented technology gives you smooth tracking on almost any surface so you can be productive wherever you work.
A trackball design with a long, broad palm area and gentle curves keeps your hand comfortable and supported all day-whether you use your right or left hand -
Stable base
Your hand stays comfortable all day long with this stay-put design. Plus, it saves you space -
Buttons let you easily move forward and backward when you're surfing the Web -
You'll enjoy fast, accurate cursor movement with just a move of your finger -
Our patented technology gives you smooth tracking on almost any surface so you can be productive wherever you work -
All-day comfort
Whichever hand you use, this mouse keeps you comfortable and supported all day-and stays in one place -
Back and forth
Convenient Forward and Backward buttons help you get around the Web with ease -
Marble marvel
Fast, accurate control is right at your fingertip with smooth-tracking Marble optical technology
- Logitech Trackman Marble - trackball - USB
- Trackball
- Connectivity Technology
- Wired - USB
- Orientation
- Right and left-handed
- Movement Detection Technology
- Optical
- Buttons Qty
- 4
- Logitech Marble optical technology
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
- Microsoft Certification
- Works with Windows Vista
- 3-year warranty
- Trackball
- Orientation
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 4
- 1 x USB - 4 pin USB Type A
- Cables Included
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Software Included
- Drivers & Utilities
- OS Required
- Additional Requirements
- CD-ROM, USB port
- Limited warranty - 3 years
