Logitech Tap Wall Mount - Video Conferencing Controller Mount Kit
Quicklinx: FPLPWS00 Mfr#: 939-001817
£188.44 ex VAT
£226.12 inc VAT
Designed to conserve table space in huddle rooms and for stand-up operation in hallways and open areas, the Logitech Tap Wall Mount offers convenient access to touch controls.
  • LOGITECH TAP WALL MOUNT
    Designed to conserve table space in huddle rooms and for stand-up operation in hallways and open areas, the Logitech Tap Wall Mount offers convenient access to touch controls. A magnetic cable dock neatly holds an HDMI cable for wired content sharing
  • Mounts Flush and Stays Put
    The sturdy plate and cleat construction holds Tap securely in place and adds virtually no thickness for a sleek appearance
  • Convenient Content Sharing
    When using Tap with applications that support wired content sharing, a magnetic cable clip and dock keep an HDMI cable within reach but out of the way
  • Supports In-Wall Cabling
    Compatible with Tap's rear and bottom cable exits so you can route cabling either within or down the wall
Logitech Tap Wall Mount - video conferencing controller mounting kit
Video conferencing controller mounting kit
Package Content
Mounting hardware
24.4 cm x 17.9 cm x 5.8 cm
14° tilt
Room Solution Base Bundle, Huddle, Large; Tap
Package Content
Mounting hardware
24.4 cm
17.9 cm
5.8 cm
14° tilt
Limited warranty: - 2 years
Logitech Room Solution Base Bundle, Huddle, Large , Logitech Tap
Brand: Logitech
