Logitech Tap Table Mount
Quicklinx: G01YWS00 Mfr#: 939-001811
Hurry, only 2 left in stock!
£177.86 ex VAT
£213.43 inc VAT
Designed for conference room tables with grommet holes, the Table Mount secures Tap in place while maintaining a low profile. Tap Table Mount maintains a clean tabletop by routing cables through the grommet hole, and swivels 180° for convenient operation from both sides of the table.
  • LOGITECH TAP TABLE MOUNT
    Designed for conference room tables with grommet holes, the Table Mount secures the touch controller in place while maintaining a low profile. Tap Table Mount maintains a clean tabletop by routing cables through the grommet hole, and swivels 180° for convenient operation from both sides of the table
  • Low-Profile with Pivot
    Preserves the touch controller's sleek appearance and 14° screen angle while swiveling 180° for viewing and operation from multiple seats
  • Fits Most Tables
    Adjusts to tables up to 50mm (2 in) in thickness, and through grommet holes from 51 - 89mm (2 - 3.5 in) in diameter
  • Integrated Cable Management
    Supports down-routing of cables through the grommet hole for a clean appearance
Logitech Tap Table Mount - video conferencing controller mounting kit
Video conferencing controller mounting kit
Package Content
Mounting hardware
24.4 cm x 17.9 cm x 6.1 cm
180° rotation, for 20-50 mm table, 51-89 mm diameter hole
Room Solution Base Bundle, Huddle, Large; Tap
Package Content
Mounting hardware
24.4 cm
17.9 cm
6.1 cm
Limited warranty: - 2 years
Logitech Room Solution Base Bundle, Huddle, Large , Logitech Tap
Brand: Logitech
