Logitech TAP Scheduler - Graphite
Quicklinx: GK79WS00 Mfr#: 952-000091
More than 50 In Stock
£562.80 ex VAT
£675.36 inc VAT
Tap Scheduler makes it easy to see meeting details and reserve a room for ad hoc or future meetings. Easily deploy as a purpose-built scheduling panel for leading room scheduling solutions to help workers find and claim the right space.
  • RIGHT PLACE, RIGHT TIME
  • GREEN MEANS GO
    Quickly find an open room through colored LED lights that show availability at a distance
  • CLEAN AND EASY INSTALL
    Included mounts and clean cabling help ensure a tidy and professional setup
  • Glass Mounting
    Secure Tap Scheduler while maintaining a clean look on both sides of the glass
  • Mullion Mounting
    Secure Tap Scheduler to a door or window frame for greater visibility using the included mount
  • Wall Mounting
    Place and secure Tap Scheduler anywhere on a wall
  • Angle Mounting
    Mount and secure at a comfortable angle for viewing with Tap Scheduler Angle Mount. LEARN MORE HERE>
  • Cable Management
    Hide cables in the wall, mullion, or in other directions, with multiple routing options
  • PURPOSE-BUILT AS A SCHEDULING PANEL
    Tap Scheduler was designed for easy viewing and usability, with a spacious screen and a sleek, unobtrusive profile. Count on Tap Scheduler for reliable performance with durable components that are built to last
  • MAKE THE MOST OF YOUR SPACE
    Easily add Tap Scheduler to a variety of meeting rooms, from phone booths to video rooms to hangout nooks, helping employees quickly find the right meeting location. Simple installations and an intuitive user experience drive fast deployment and adoption
  • Logitech Select
    AN ALL-IN-ONE SERVICE PLAN Logitech Select is a comprehensive service plan that delivers reliability, continuity, and peace of mind for each room you designate. Select provides 24/7 support, a dedicated Customer Success Manager, Available with purchase of a service plan with 50 or more rooms. product replacement, accelerated RMA, onsite spares, Available with purchase of a service plan with 50 or more rooms. and advanced Sync analytics including customizable alerts through ServiceNow integration. Available for users of Logitech Sync. LEARN MORE ABOUT LOGITECH SELECT>
  • Extended Warranty
    UP TO FIVE YEAR WARRANTY Purchasing an extended warranty Terms and conditions apply. Not available in all countries. Contact your reseller.  offers security and peace of mind that comes with knowing your Logitech video collaboration room systems and devices are protected against defects for up to five years from the purchase date. Extended warranties are available for either one year or three years beyond the original Logitech manufacturer's two-year warranty. LEARN MORE ABOUT EXTENDED WARRANTY>
Logitech Tap Scheduler Purpose-Built Scheduling Panel for Meeting Rooms - video conferencing device
Video conferencing device
24.62 cm x 2.85 cm x 16.5 cm
Display
10.1" IPS / 1280 x 800
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet, Fast Ethernet, Bluetooth 5.0
Software Certification
Certified for Microsoft Teams, Zoom Certified
24.62 cm
2.85 cm
16.5 cm
Dimensions & Weight Details
Surface mounted - Width 3.14 cm Depth 24.62 cm Height 16.5 cm , Mullion mounted - Width 29.26 cm Depth 4.45 cm Height 16.5 cm
Built-in Devices
Accelerometer
Enclosure Colour
Graphite
Display
IPS
Diagonal Size
10.1"
Native Resolution
1280 x 800
Image Brightness
400 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-fingerprint, durable display, touch screen, LED-backlit, 85° viewing angle, 10-point multi-touch, ambient lighting, 100 x 100 VESA mounting
Wired, wireless
ARM TrustZone
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 5.0, IEEE 802.3af
1 x network - Ethernet 10Base-T/100Base-TX (PoE) - RJ-45
Mounting hardware
VESA FDMI, AES-128
10 - 95%
Brand: Logitech
Price Range Ex VAT: £500 - £750
