Logitech Tap Riser Mount
Quicklinx: FPMDWS00 Mfr#: 939-001814
Designed for conference room tables with center-located grommet holes, the Riser Mount secures Tap in place and elevates the display angle to 30° for easier operation while seated.
  • LOGITECH TAP RISER MOUNT
    Designed for conference room tables with center-located grommet holes, the Riser Mount secures the touch controller in place and elevates the display angle to 30° for better visibility and easier operation while seated. Tap Riser Mount maintains a clean tabletop by routing cables through the grommet hole, and swivels 180° for convenient operation from both sides of the table
  • RAISED PROFILE FOR AN EASIER REACH
    Elevates the touch controller to a 30° display angle and swivels 180° for easier operation when reaching a center-of-table mounting location
  • FITS MOST TABLES
    Adjusts to tables up to 50mm in thickness, and through grommet holes from 51 - 89mm in diameter
  • INTEGRATED CABLE MANAGEMENT
    Supports down-routing of cables through the grommet hole for a clean appearance
Logitech Tap Riser Mount - video conferencing controller mounting kit
Video conferencing controller mounting kit
Package Content
Mounting hardware
24.4 cm x 17.9 cm x 10.2 cm
180° rotation, 30° tilt, for 20-50 mm table, 51-89 mm diameter hole
Logitech Tap
Package Content
Mounting hardware
24.4 cm
17.9 cm
10.2 cm
Limited warranty: - 2 years
Logitech Tap
