Logitech Tap IP Appliance Room Solutions Huddle + Small Room (Tap IP, Rally Bar Huddle)
Quicklinx: HKHRWS00 Mfr#: 991-000482
Hurry, only 2 left in stock!
£1,992.52 ex VAT
£2,391.02 inc VAT
Full solution featuring an all-in-one video bar and touch controller with PoE connectivity. Ideal for huddle and small rooms up to 6 people.
  • Premier all-in-one video bar for huddle rooms and small spaces
    Enjoy quick and easy setup and management with this Logitech all-in-one video bar for huddle rooms and small spaces.
  • Clean and secure cabling
    Route cables from above or below: thoughtful cable management hides cable clutter and keeps connections tight. This minimizes visible cabling, prevents downtime due to accidental disconnections, and supports mounting positions above and below the display.
  • Multiple mounting options
    One mount, three different ways. Attach Rally Bar Huddle to a display, table, or wall to get the most out of your huddle rooms and small spaces.
  • Start meetings with a tap
    Meetings start with just one touch with Tap IP, a network-connected touch controller that's easy to use and simple to set up.
Logitech Tap IP Appliance Room Solutions Huddle + Small Rooms - video conferencing kit
Video conferencing kit
Kit Content
Logitech Tap IP, Logitech Rally Bar Huddle
54.96 cm x 7.6 cm x 7.89 cm
1.8 kg
Video Input
Digital video camera - SuperSpeed USB 3.0
Audio Input
6-microphone array - omni-directional, beamforming
Audio Output
Speaker(s)
Input Device
10.1" touchscreen (wireless, wired)
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth LE
AC 100-240 V
Apple MacOS, Microsoft Windows 10 / 11
Kit Content
54.96 cm
7.6 cm
7.89 cm
1.8 kg
Dimensions & Weight Details
Power adapter - Width 11.4 cm Depth 4.7 cm Height 3.23 cm , Touch screen - Width 24.62 cm Depth 17.13 cm Height 5.61 cm Weight 1 kg , Video bar - Width 54.96 cm Depth 7.6 cm Height 7.89 cm Weight 1.8 kg
Enclosure Colour
Graphite
Video Input
Digital video camera (colour) - desktop
Interface Type
SuperSpeed USB 3.0
Digital Video Capture Resolution
3840 x 2160
Video Modes
4K
Digital Zoom
4
Camera Mechanical Design
Pan / tilt / zoom
Motorised privacy shutter, Acoustic Echo Cancellation (AEC), microphone noise suppression technology, 120° diagonal field of view, 113° field of view (horizontal), Voice Activity Detector (VAD), 80° field of view (vertical), AI-powered, -48° / +48° pan, -32° / +32° tilt
Audio Input
6-microphone array - integrated
Microphone Operation Mode
Omni-directional, beamforming
Frequency Response
90 - 16000 Hz
Audio Output
Speaker(s)
Total Harmonic Distortion (THD)
<2%
Input Device
10.1" touchscreen
Wireless, wired
VESA 100 x 100 mm, 14° display angle, 1280 x 800 resolution
Wireless, wired
Network / Transport Protocol
IPv4, IPv6
128-bit encryption, Multicast Proxy support, cable management, AES encryption, ARM TrustZone, Public Key Infrastructure (PKI)
IEEE 802.3af
1 x audio / video - HDMI input , 1 x audio / video - HDMI output , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB 3.1 - 9 pin USB Type A , 1 x USB-C 3.1 - 24 pin USB-C
1 x HDMI cable - 2 m , 1 x USB 3.0 Type C to Type A cable - 2.2 m
Mounting Kit
Included
AES-128, FSC, CarbonNeutral
Power adapter - external
AC 100-240 V
10 - 90%
Brand: Logitech
Price Range Ex VAT: £1500+
