Transform your space into a Google Meet meeting place or a Microsoft Teams Rooms on Windows with Logitech Tap. Deliver one-touch join, calendar integration, easy content-sharing, and a consistent experience across all rooms. For the latest certification and compatibility information, click here .
Table Mount
Secures Tap to a grommet while maintaining a low profile. Swivels 180° for convenient operation from both sides of the table -
Riser Mount
Secures Tap to a grommet and raises the viewing angle from 14° to 30° for better visibility from across the room. Swivels 180° for convenient operation from both sides of the table -
Wall Mount
Conserve table space and mount Tap flush to the wall with a sturdy plate and cleat design -
PC Mount
Mount a small form factor PC or Chromebox beneath a table or behind a display. Includes two-piece cable retention clamp to keep USB, HDMI, power, and network cables tight and secure -
Logitech Strong USB
Aramid-reinforced, plenum-rated and Eca compliant for high pull-strength and durability in walls, above ceilings, or within standard 20 mm conduit. 10 meters included, 25 meters optional
- Logitech Tap - controller - with Logitech Cat5e Kit
- Product Type
- Controller
- Functions
- Video conferencing room control
- Integrated Components
- Speaker
- Bundled with
- Logitech Cat5e Kit
- Connectivity
- Wired
- Input Type
- Touch screen
- Display
- 10.1"
- 24.4 cm x 17.9 cm x 5.8 cm
- Designed For
- Room Solution Large
- Product Type
- Controller
- Functions
- Speaker
- Bundled with
- Connectivity Technology
- Wired
- OS Required
- Google Chrome OS, Windows 10
- Display
- 10.1"
- Display Resolution
- 1280 x 800 pixels
- Interfaces Details
- Headphone output , HDMI input , USB-C 3.1 , USB 3.1
- Anti-theft protection security slot (Kensington security lock compatible)
Control Unit
- Input Type
- Touch screen
Camera
- Motion sensor
- Included Accessories
- Power adapter, cleaning cloth, 4 screws, USB Type A to USB-C cable
- Nominal Voltage
- AC 100 - 240 V
- VESA FDMI
- 24.4 cm
- 17.9 cm
- 5.8 cm
- 1.25 kg
- Designed For
- Logitech Room Solution Large
Logitech Tap Wall Mount - Video Conferencing Controller Mount Kit | In Stock | £184.34 |
Logitech Tap Table Mount | In Stock | £184.34 |
