Logitech Tap Controller with Cat5e Kit
Quicklinx: GVPHWS00 Mfr#: 939-001950
28 In Stock
£840.78 ex VAT
£1,008.93 inc VAT
Transform your space into a Google Meet meeting place or a Microsoft Teams Rooms on Windows with Logitech Tap. Deliver one-touch join, calendar integration, easy content-sharing, and a consistent experience across all rooms. For the latest certification and compatibility information, click here .
  • Table Mount
    Secures Tap to a grommet while maintaining a low profile. Swivels 180° for convenient operation from both sides of the table
  • Riser Mount
    Secures Tap to a grommet and raises the viewing angle from 14° to 30° for better visibility from across the room. Swivels 180° for convenient operation from both sides of the table
  • Wall Mount
    Conserve table space and mount Tap flush to the wall with a sturdy plate and cleat design
  • PC Mount
    Mount a small form factor PC or Chromebox beneath a table or behind a display. Includes two-piece cable retention clamp to keep USB, HDMI, power, and network cables tight and secure
  • Logitech Strong USB
    Aramid-reinforced, plenum-rated and Eca compliant for high pull-strength and durability in walls, above ceilings, or within standard 20 mm conduit. 10 meters included, 25 meters optional
Logitech Tap - controller - with Logitech Cat5e Kit
Controller
Functions
Video conferencing room control
Integrated Components
Speaker
Bundled with
Logitech Cat5e Kit
Wired
Input Type
Touch screen
Display
10.1"
24.4 cm x 17.9 cm x 5.8 cm
Room Solution Large
Controller
Functions
Speaker
Bundled with
Logitech Cat5e Kit
Wired
Google Chrome OS, Windows 10
Display
10.1"
Display Resolution
1280 x 800 pixels
Interfaces Details
Headphone output , HDMI input , USB-C 3.1 , USB 3.1
Anti-theft protection security slot (Kensington security lock compatible)
Control Unit
Input Type
Touch screen
Camera
Motion sensor
Power adapter, cleaning cloth, 4 screws, USB Type A to USB-C cable
Nominal Voltage
AC 100 - 240 V
VESA FDMI
24.4 cm
17.9 cm
5.8 cm
1.25 kg
Logitech Room Solution Large
GVPH Logitech Tap Wall Mount - Video Conferencing Controller Mount Kit In Stock £184.34
GVPH Logitech Tap Table Mount In Stock £184.34
Brand: Logitech
Price Range Ex VAT: £750 - £1000
