Logitech Studio Series Desk Mat - Mid Grey
Quicklinx: HJ4WWS00 Mfr#: 956-000052
25 In Stock
£11.58 ex VAT
£13.89 inc VAT
Meet the accessory that takes your workspace to the next level, perfectly complementing your Logitech tools. Get the fresh pop of color you crave, the comfort you need, and the desk protection you expect.
  • YOUR WORKSPACE. DEFINED
  • ELEVATE YOUR SPACE
    Boost your space and protect your desk. The soft cloth mat delivers style and comfort. Get it in Lavender, Dark Rose, Mid Gray or Lilac
  • SPILL RESISTANT
    Logitech Desk Mat features a spill-proof coating that withstands accidental mishaps, so liquids can easily be wiped away
  • ALL GLIDE. NO SLIDE
    The soft surface fabric provides a comfortable mousing experience, while the rubber anti-slip base prevents sliding on any surface, keeping a firm hold on your desk no matter what
  • BEAUTY THAT LASTS
    Carefully selected materials that prevent the mat from wrinkling and shrinking, while a flat-stitched design protects the edges from fraying. The anti-slip base features natural rubber , while the soft, comfortable surface fabric and inner layer are made from recycled polyester, giving a second life to PET bottles
  • MIX, MATCH, PAIR
    Get the curated workspace that unleashes your personality. Logitech Desk Mat pairs perfectly with the playful Logitech POP Icon Combo with customizable productivity hacks. Add a modern webcam and headset to complete your work-from-home setup. Great video and audio go a long way in boosting communication in virtual meetings and presentations
  • A MORE COMPACT PAD
    Meet the soft, smooth, slightly smaller no-slip mouse pad that elevates your workspace. Made from high-quality materials, Logitech Mouse Pad gives you the glide and comfort you need, along with your favorite Logitech Mouse
Logitech Studio Series Desk Mat - keyboard and mouse pad
Keyboard and mouse pad
Product Material
100% recycled polyester, rubber, nylon, polyester
70 cm x 30 cm
286 g
Mid grey
Product Material
70 cm
30 cm
Thickness
2 mm
286 g
Mid grey
Spill-resistant, anti-slip base, anti-fraying stitched edges
Brand: Logitech
