Logitech Strong USB cable USB Type A (M) to USB-C (M) USB 3.1 10m
Quicklinx: FXZ0WS00 Mfr#: 939-001799
Length: 10m
43 In Stock
£260.34 ex VAT
£312.40 inc VAT
With more than 3x the reach of ordinary USB 3.x cables, Logitech Strong USB lets you separate self-powered USB 2.0 and 3.x peripherals and a host PC by up to 10 meters. The aramid-reinforced active optical cable is plenum-rated and Eca certified for safe operation and reliable performance to 10Gbps. By eliminating the need for USB extenders, Logitech Strong USB eliminates points of failure while reducing cost and complexity. Unlike typical USB cables that can break during or after installation, Logitech Strong USB is plenum-rated and Eca certified to pull through walls, above ceilings, and within standard ¾" conduit.
  • EXTENDED REACH
    Available in 10, 25, and 45 meter lengths, Logitech Strong USB lets you deploy a self-powered USB device or hub at a significant distance from its host PC. Locate devices like the Logitech Tap touch controller for easy access, but hide the host PC in a cabinet, closet, or behind a display
  • RELIABLE STRENGTH
    Unlike ordinary USB cables that can break when subject to pulling and crushing forces, Logitech Strong USB is built to last. With 200 newtons of tensile strength and a 1000 kg crush load, Logitech Strong USB stands up to commercial deployments in walls, above ceilings, and through conduit
  • FAST AND COMPATIBLE
    As an active optical cable, Logitech Strong USB delivers up to 10 Gbps for devices with their own power supplies, including Logitech Tap , Rally Camera , and Meetu p. Compliance with the USB 3.2 Gen 2 specification assures backward compatibility with USB 2.0, 3.0, 3.1, and 3.2 devices and computers
Logitech Strong - USB-C cable - USB Type A to 24 pin USB-C - 10 m
USB-C cable
Plenum, Active Optical Cable (AOC), aramid-reinforced sheath, 3/4" conduit friendly
Length
10 m
Connector
9 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB 2.0 / USB 3.0 / USB 3.1
Room Solution Huddle, Large
USB-C cable
Length
10 m
Connector
24 pin USB-C - male
USB 2.0 / USB 3.0 / USB 3.1, IEC 60332-1-2
Logitech Room Solution Huddle, Large
Length: 10m
Brand: Logitech
