With more than 3x the reach of ordinary USB 3.x cables, Logitech Strong USB lets you separate self-powered USB 2.0 and 3.x peripherals and a host PC by up to 10 meters. The aramid-reinforced active optical cable is plenum-rated and Eca certified for safe operation and reliable performance to 10Gbps. By eliminating the need for USB extenders, Logitech Strong USB eliminates points of failure while reducing cost and complexity. Unlike typical USB cables that can break during or after installation, Logitech Strong USB is plenum-rated and Eca certified to pull through walls, above ceilings, and within standard ¾" conduit.
                EXTENDED REACHAvailable in 10, 25, and 45 meter lengths, Logitech Strong USB lets you deploy a self-powered USB device or hub at a significant distance from its host PC. Locate devices like the Logitech Tap touch controller for easy access, but hide the host PC in a cabinet, closet, or behind a display
                RELIABLE STRENGTHUnlike ordinary USB cables that can break when subject to pulling and crushing forces, Logitech Strong USB is built to last. With 200 newtons of tensile strength and a 1000 kg crush load, Logitech Strong USB stands up to commercial deployments in walls, above ceilings, and through conduit
                FAST AND COMPATIBLEAs an active optical cable, Logitech Strong USB delivers up to 10 Gbps for devices with their own power supplies, including Logitech Tap , Rally Camera , and Meetu p. Compliance with the USB 3.2 Gen 2 specification assures backward compatibility with USB 2.0, 3.0, 3.1, and 3.2 devices and computers
- Logitech Strong - USB-C cable - USB Type A to 24 pin USB-C - 10 m
- USB-C cable
- Plenum, Active Optical Cable (AOC), aramid-reinforced sheath, 3/4" conduit friendly
- Length
- 10 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- USB 2.0 / USB 3.0 / USB 3.1
- 2-year warranty
- Designed For
- Room Solution Huddle, Large
- USB-C cable
- Length
- 10 m
- Connector
- USB 2.0 / USB 3.0 / USB 3.1, IEC 60332-1-2
- 2-year warranty
- Designed For
- Logitech Room Solution Huddle, Large
