Logitech Strong USB cable USB Type A (M) to USB-C (M)  USB 3.1 10m
Quicklinx: FXZ0WS00 Mfr#: 939-001799
Length: 10m
32 in stock
£242.80 ex VAT
£291.36 inc VAT
With more than 3x the reach of ordinary USB 3.x cables, Logitech Strong USB lets you separate self-powered USB 2.0 and 3.x peripherals and a host PC by up to 10 meters. The aramid-reinforced active optical cable is plenum-rated and Eca certified for safe operation and reliable performance to 10Gbps. By eliminating the need for USB extenders, Logitech Strong USB eliminates points of failure while reducing cost and complexity. Unlike typical USB cables that can break during or after installation, Logitech Strong USB is plenum-rated and Eca certified to pull through walls, above ceilings, and within standard ¾" conduit.
  • In-wall rated
    Aramid-reinforced, plenum-rated and Eca compliant for high pull-strength and durability in walls, above ceilings, or within standard ¾" conduit.
  • Stays connected
    Together with Tap's internal cable retention and strain relief systems, Logitech Strong USB stays securely connected, even when users move Tap around the room.
  • Compatible
    With support for USB 3.1, 3.0, and 2.0, the active optical cable is compatible with self-powered USB Type C devices like MeetUp and Rally Camera, or any USB Type C hub with its own power supply.
  • Hides the computer
    Available in 10 and 25 meter lengths so you can move the meeting room computer - and its noise, heat, and cabling - away from participants and out of sight.
Logitech Strong USB-C cable - USB Type A to USB-C - 10 m
USB-C cable
Plenum, Active Optical Cable (AOC), aramid-reinforced sheath, 3/4" conduit friendly
Length
10 m
Connector
9 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB 2.0 / USB 3.0 / USB 3.1
USB-C cable
Length
10 m
Connector
24 pin USB-C - male
USB 2.0 / USB 3.0 / USB 3.1, IEC 60332-1-2
Length: 10m
Brand: Logitech
Stock Status: In stock
