Logitech StreamCam Webcam - Graphite
Quicklinx: FT6LWS00 Mfr#: 960-001281
Interface: USB Type-C
Compatibility: PC
£109.57 ex VAT
£131.48 inc VAT
Take your content to the next level and share your passion with Logitech StreamCam. Featuring pristine image quality, dual front-facing microphones, versatile mounting options, and USB-C connectivity, it's the perfect camera for broadcasting to your favorite streaming platforms - all you need to do is be yourself!
  • BRING YOUR STORY INTO FOCUS
    Logitech StreamCam streams and records in full HD 1080p resolution at 60 fps, delivering stunning video content with smooth motion to every aspect of your online world. From recording YouTube videos to streaming on Twitch and beyond, StreamCam's premium glass lens and smart auto-focus system make it easy to get professional-quality results. Advanced features like auto-framing and intelligent exposure ensure you always look your best in any lighting. SEE THE RECOMMENDED COMPUTER SPECIFICATIONS >
  • FULL HD 1080P AT 60 FPS
    Stream and record videos for YouTube, Twitch and more in full HD 1080p resolution at 60 frames per second. No matter what type of content you create, StreamCam produces sharp content with smooth motion that looks natural on screen
  • PREMIUM GLASS LENS WITH SMART AUTO-FOCUS
    StreamCam's premium glass lens delivers vibrant, true-to-life image quality with crisp details. A 78-degree field of view keeps you upfront and center. Auto-focus intelligently adjusts the lens in real-time so you always stay in focus, even when you move toward or away from the camera
  • AUTO-FRAMING AND INTELLIGENT EXPOSURE
    The smart auto-framing mode dynamically adjusts the framing to keep you in the center of the shot, even as you move left or right. The intelligent exposure system adjusts aperture and ISO speed in real-time to ensure accurate skin tones for a more natural, healthy look-even in varying lighting conditions. With StreamCam, you can be confident that you'll always look great
  • OPTIMIZED FOR POPULAR LIVE STREAMING SOFTWARE
    StreamCam is optimized for Open Broadcaster Software (OBS), XSplit, Streamlabs OBS and other popular live streaming software. Effortlessly stream to Twitch, YouTube and all of your favorite streaming sites
  • ENHANCED CONTROL WITH LOGITECH CAPTURE SOFTWARE
    Ready to take your content to the next level? Combine StreamCam with the included Logitech Capture software to unlock powerful features that automate focus exposure and more
  • CONNECTS WITH USB-C
    The standard for fast and reliable connections, StreamCam uses USB Type-C to ensure efficient video transfer speeds. Compatible with Windows 10 and macOS 10.14 and above
  • SMART AUTO-FRAMING
    StreamCam uses Logitech Capture to automatically keep you framed front and center in all your streams and videos
  • PREMIUM AUDIO PERFORMANCE
    Sound more authentic and vibrant to your audience whether you're singing a song or sharing a story with dual front-facing microphones
  • OBS, XSPLIT AND STREAMLABS SUPPORT
    Logitech StreamCam is optimized for Open Broadcaster Software (OBS), XSplit and Streamlabs so you can effortlessly stream to Twitch, YouTube, and other platforms
Logitech StreamCam - live streaming camera
Live streaming camera
Audio
Yes: built-in dual omni-directional microphones
5.8 cm x 4.8 cm x 6.6 cm
150 g
Graphite
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
Video Modes
1080p
Focal Length
3.7 mm
Focus Adjustment
Automatic (min distance 10 cm)
Lens Iris
F/2.0
USB-C 3.1 Gen 1
1 - USB-C 3.1 cable - integrated - 1.5 m
Auto exposure control, LED indicator, noise reduction, electronic image stabilisation
1-year warranty
Audio Support
Wired
5.8 cm
4.8 cm
6.6 cm
150 g
Camera
Digital Video Format
MJPEG, YUY2
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Digital Video Capture Resolution
1280 x 720, 320 x 240, 1920 x 1080, 640 x 360, 848 x 480, 960 x 540
Frame Rate (max)
Still Image Capture Resolution
1080p
Lens Construction
Focal Length
3.7 mm
Lens Iris
F/2.0
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Diagonal Field of View (degree)
78
Computer Interface
USB-C 3.1 Gen 1
Monitor mount, tripod adapter
1 x USB-C 3.1 cable - integrated - 1.5 m
Graphite
Software Included
XSplit (3 months Premium licence)
Windows 10 or later, Apple macOS 10.14 or later
Limited warranty - 1 year
Compatibility: PC
Brand: Logitech
