Speak clearly with this simple, easy-to-use analog headset. With full stereo sound, your headset is great for voice and video calls. The noise-canceling microphone cuts background noise - and rotates out of the way when you're not using it. Just plug your headset into the 3.5 mm input and output jacks on your computer and it's ready to go. Simple as that!
ENJOY CRISP, CLEAR INTERNET CALLS AND MUSIC FROM YOUR PC
Versatile and adjustable, for computers that utilize separate 3.5 mm microphone-in and audio-out ports. In-line controls let you control volume or mute calls without disruption. Convenient noise-cancelling microphone reduces background noise -
Stereo sound
Full stereo sound for crisp, clear voice and video calls, music, games and more. An essential stereo headset for either personal use or the office -
Rotating microphone
Boom can rotate 180° to be worn on the left or right. Flexible mic can be positioned for better voice capture and background noise reduction. Boom can be tucked out of the way when you're not using it -
In-line controls
Convenient in-line controls on the headset cord let you adjust the volume or mute calls without disruption -
Adjustable headband
Sturdy yet lightweight stereo headset has a broad range of adjustment. Ultra-soft foam ear cushions provide hours of comfort -
Dual Plug Connection
Connects to computers that utilize separate 3.5 mm audio jacks for microphone-in and audio-out ports. Not compatible with Chromebook , tablets or Mac
- Logitech Stereo Headset H150 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Blueberry
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Microphone
- Built-in - boom
- Microphone Operation Mode
- Mono
- 2-year warranty
- Product Type
- Headset - wired
- Blueberry
- Recommended Use
- Computer
Audio Output
- On-ear binaural
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- In-Cord Volume Control
Microphone
- Boom
- Mono
- Connector Type
- Audio line-out (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
- Cable Details
- Headset cable
- Limited warranty - 2 years
