Logitech Stereo H151 Headset - On-Ear - Wired
Quicklinx: G5VBWS00 Mfr#: 981-000589
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
18 In Stock
£19.61 ex VAT
£23.53 inc VAT
Essential stereo headset works on all operating systems and platforms via the standard 3.5mm audio jack connection. Just plug your headset into the 3.5mm port on your computer, tablet or smartphone and it's ready to go. In-line controls let you control volume or mute calls without disruption. Convenient noise-cancelling microphone reduces background noise.
  • STEREO SOUND
    Full stereo sound for crisp, clear voice and video calls, music, games and more. An essential stereo headset for either personal use or the office
  • ROTATING MICROPHONE
    Boom can rotate 180° to be worn on the left or right. Flexible mic can be positioned for better voice capture and background noise reduction. Boom can be tucked out of the way when you're not using it
  • IN-LINE CONTROLS
    Convenient in-line controls on the headset cord let you adjust the volume or mute calls without disruption
  • ADJUSTABLE HEADBAND
    Sturdy yet lightweight stereo headset has a broad range of adjustment. Ultra-soft foam ear cushions provide hours of comfort
  • 3.5MM AUDIO JACK CONNECTION
    Simply plug the 3.5mm audio jack into your computer, smartphone or tablet and you're ready to talk
Logitech Stereo H151 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 122 dB
Impedance
22 Ohm
Microphone
Boom
Controls
Volume, microphone on/mute
Headset - wired
15 cm
20 cm
6 cm
80 g
Recommended Use
Computer
Audio Output
On-ear
Dynamic
Wired
Sound Output Mode
Stereo
Sensitivity
122 dB
Impedance
22 Ohm
In-Cord Volume Control
Microphone
Boom
Sensitivity
-44 dBV/Pascal
Frequency Response
100 - 6500 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable Details
Headset cable - 1.8 m
Shipping Width
6.99 cm
Shipping Depth
19.1 cm
Shipping Height
23.97 cm
Shipping Weight
263 g
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
