Essential stereo headset works on all operating systems and platforms via the standard 3.5mm audio jack connection. Just plug your headset into the 3.5mm port on your computer, tablet or smartphone and it's ready to go. In-line controls let you control volume or mute calls without disruption. Convenient noise-cancelling microphone reduces background noise.
STEREO SOUND
Full stereo sound for crisp, clear voice and video calls, music, games and more. An essential stereo headset for either personal use or the office -
ROTATING MICROPHONE
Boom can rotate 180° to be worn on the left or right. Flexible mic can be positioned for better voice capture and background noise reduction. Boom can be tucked out of the way when you're not using it -
IN-LINE CONTROLS
Convenient in-line controls on the headset cord let you adjust the volume or mute calls without disruption -
ADJUSTABLE HEADBAND
Sturdy yet lightweight stereo headset has a broad range of adjustment. Ultra-soft foam ear cushions provide hours of comfort -
3.5MM AUDIO JACK CONNECTION
Simply plug the 3.5mm audio jack into your computer, smartphone or tablet and you're ready to talk
- Logitech Stereo H151 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Sensitivity 122 dB
- Impedance
- 22 ohm
- Microphone
- Boom
- Controls
- Volume, microphone on/mute
- 2-year warranty
- Product Type
- Headset - wired
- 15 cm
- 20 cm
- 6 cm
- 80 g
- Recommended Use
- Computer
Audio Output
- On-ear
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- Sensitivity
- 122 dB
- Impedance
- 22 ohm
- In-Cord Volume Control
Microphone
- Boom
- Sensitivity
- -44 dBV/Pascal
- Frequency Response
- 100 - 6500 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
- Cable Details
- Headset cable - 1.8 m
- Limited warranty - 2 years
- Shipping Width
- 6.99 cm
- Shipping Depth
- 19.1 cm
- Shipping Height
- 23.97 cm
- Shipping Weight
- 263 g
Logitech Stereo H151 Headset - On-Ear - Wired
