Spotlight and its companion app work together to deliver a deep range of intelligent and customizable features. You'll step confidently onto stage, and right into your zone.
LONG OPERATING RANGE
Move and present freely from as far as 30 m away May vary based on environmental and computing conditions. -
BROAD COMPATIBILITY
Use Spotlight on Windows and macOS platforms; Powerpoint , Keynote , Acrobat , Google Slide and Prezi presentations; as well as Zoom , Microsoft Teams , and Blue Jeans video conferencing apps -
TWO WAYS TO CONNECT
Plug-and-play Spotlight instantly on any compatible computer via USB receiver, or connect with Bluetooth low energy wireless technology. Spotlight also keeps your computer connected and awake while you present -
FAST RECHARGING
Use the included USB-C charging cable and get 3 hours of presenting after a 1-minute charge. Spotlight fully charges in as little as 60 minutes. The device will vibrate and the battery indicator glows red when it's time to recharge
- Logitech Spotlight presentation remote control - slate
- Presentation remote control
- Enclosure Colour
- Slate
- 2.81 cm x 1.21 cm x 13.13 cm
- 49.2 g
- Supported Devices
- Notebook, personal computer
- Wireless Technology
- Bluetooth, 2.4 GHz
- Buttons Qty
- 3 buttons
- Max Operating Distance
- 30 m
- Battery
- Rechargeable - lithium polymer
- 2-year warranty
- 2.81 cm
- 1.21 cm
- 13.13 cm
- 49.2 g
- Enclosure Colour
- Slate
- Supported Devices
- Buttons Qty
- 3 buttons
- 30 m
- Gyroscopic motion-sensing technology, power on/off
- Connector Type
- 1 x USB
- Operating System
- Linux, Windows RT, MS Windows 7 or later, Apple Mac OS X 10.10 or later, Chrome OS
- Included Accessories
- Carrying pouch, USB wireless receiver, mini-USB charging cable
- Battery
- Capacity
- 85 mAh
- Run Time (Up To)
- 3 months
- Recharge Time
- 1 hour
- Limited warranty - 2 years
