Logitech Speaker System S120 2.0 - Black
Quicklinx: B24BWS00 Mfr#: 980-000010
Logitech's S-120 stereo speaker system with its refresh design features enhanced acoustics delivering a smooth audio performance with low distortion. The S-120 speaker with its redesigned base offers sturdy design, strong audio performance and exceptional value for money. The integrated power and volume control is conveniently located on the satellite at your fingertips with an essential 3.5mm jack close by.
  • Crisp audio quality
    Experience clear and detailed sound for your multimedia content, including music and videos, with the Logitech S-120 speakers. The integrated amplifier and active amplification type ensure a powerful audio performance that enhances your listening experience.
  • Easy control
    Adjust your audio settings on the fly with the convenient volume control. Whether you're in the middle of a game or listening to music, you have the power to control the sound level at your fingertips without interrupting your digital experience.
  • Seamless setup
    With a simple wired connectivity technology, these speakers are easy to set up and use with your PC. The AC power adapter ensures your speakers are always ready to deliver the sound you need without the hassle of batteries.
Logitech S-120 - speakers - for PC
Speakers - for PC
Europe
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
2.3 Watt
Frequency Response
50 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 1.15 Watt - 50 - 20000 Hz
AC 230V
3-year warranty
Speakers - for PC
Enclosure Colour
Europe
Speaker System
System Components
2 speakers
Speaker Type
Active
Audio System Continuous Power (Total)
2.3 Watt
Frequency Response
50 - 20000 Hz
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 - 1.15 Watt - 50 - 20000 Hz - wired
Connector Type
Audio line-in , Headphones (mini-phone stereo 3.5 mm)
Packaging Type
OEM
Audio cable
Power supply - internal
Power Source
AC power adapter
AC 230V
Limited warranty - 3 years
