Logitech's S-120 stereo speaker system with its refresh design features enhanced acoustics delivering a smooth audio performance with low distortion. The S-120 speaker with its redesigned base offers sturdy design, strong audio performance and exceptional value for money. The integrated power and volume control is conveniently located on the satellite at your fingertips with an essential 3.5mm jack close by.
Crisp audio quality
Experience clear and detailed sound for your multimedia content, including music and videos, with the Logitech S-120 speakers. The integrated amplifier and active amplification type ensure a powerful audio performance that enhances your listening experience. -
Easy control
Adjust your audio settings on the fly with the convenient volume control. Whether you're in the middle of a game or listening to music, you have the power to control the sound level at your fingertips without interrupting your digital experience. -
Seamless setup
With a simple wired connectivity technology, these speakers are easy to set up and use with your PC. The AC power adapter ensures your speakers are always ready to deliver the sound you need without the hassle of batteries.
- Logitech S-120 - speakers - for PC
- Product Type
- Speakers - for PC
- Localisation
- Europe
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power (Total)
- 2.3 Watt
- Frequency Response
- 50 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 1.15 Watt - 50 - 20000 Hz
- Black
- Power
- AC 230V
- 3-year warranty
- Product Type
- Speakers - for PC
- Enclosure Colour
- Black
- Localisation
- Europe
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 2.3 Watt
- 50 - 20000 Hz
- Amplifier
- Integrated
- Controls
- Power on/off, volume
- Speakers Included
- 2 - 1.15 Watt - 50 - 20000 Hz - wired
- Connector Type
- Audio line-in , Headphones (mini-phone stereo 3.5 mm)
- Packaging Type
- OEM
- Included Accessories
- Audio cable
- Power Device
- Power supply - internal
- Power Source
- AC power adapter
- Voltage Required
- AC 230V
- Limited warranty - 3 years
