Logitech Slim Keyboard/Mouse Combo MK470 - Graphite
Quicklinx: GDR1WS00 Mfr#: 920-009202
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: PC
27 In Stock
£35.05 ex VAT
£42.06 inc VAT
Own your space with the MK470 Slim Combo - an ultra-thin and design-forward keyboard and mouse combo perfect for getting things done efficiently and quietly, even in the tightest desk spaces.
  • OWN YOUR SPACE
    Make any space minimalist, modern, and whisper-quiet with the MK470 Slim Wireless Combo – an ultra-thin, compact and design-forward keyboard and mouse combo perfect for getting things done efficiently
  • MINIMALIST. MODERN. SLIM
    The MK470 Slim Combo stands out for its simplicity. The slim profile and minimalist design transform your keyboard and mouse into a visual statement for a clean, sleek desk setup
  • SPACE-SAVING PRODUCTIVITY
    The compact keyboard includes a number pad and 12 FN shortcuts, giving you all the keys you need. The slim mouse is extra portable and you can easily store it in your laptop bag or in your pocket for on-the-go productivity. The combo's smaller footprint means you can work on the tightest desk spaces and keep your mouse comfortably within reach
  • FLUID, COMFORTABLE TYPING & MOUSING
    Low-profile scissor keys provide a fluid and familiar laptop-like typing experience. The smooth pebble shape of the ambidextrous mouse feels great in either hand
  • WHISPER-QUIET WORK
    A quiet keyboard and lab-tested, 90% noise-reduced mouse mean an ultra quiet work experience for you and those around you
  • EASY, RELIABLE WIRELESS
    A simple plug-and-play USB receiver offers a strong 2.4 GHz wireless connection with 10 meters of range . This means you will have a clean, cable-free desk and the freedom to arrange your devices the way you want-where you want
  • GO LONGER BETWEEN BATTERIES
    18-month battery life for the mouse, and 36-month battery life for the keyboard means you don't have to worry about losing power. Both accessories go into battery-saving sleep mode when not in use
  • COMPLETE WITH AUDIO AND VIDEO
    Great video and audio go a long way in boosting communication in virtual meetings and presentations. Add a modern webcam and headset to complete your work-from-home setup. Choose matching colorways or mix and match!
  • HOW TO SET UP KEYBOARD. STEP 1
    Remove the Pull-Tab First, pull the tabs protecting the batteries from your mouse and keyboard. Your Slim Combo MK470 will automatically turn on
  • STEP 2
    Connect via USB. Insert the USB receiver in any available USB port on your desktop or laptop. Your keyboard and mouse will be ready to use
  • STEP 3
    How to remove the keyboard battery. Slide the upper part of the keyboard up to find the batteries and receiver storage inside
Logitech Slim Wireless Combo MK470 - keyboard and mouse set - QWERTY - UK - graphite Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
Nano USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Numeric Keypad
Pointing Device
Mouse - wireless - optical - right and left-handed
Buttons Qty
3
Graphite
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 37.35 cm x 14.39 cm x 2.13 cm / 558 g , Mouse: 5.9 cm x 10.7 cm x 2.65 cm / 100 g , Wireless receiver: 1.87 cm x 0.61 cm x 1.44 cm / 1.8 g
Wireless
QWERTY UK
Numeric keypad
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Batteries:
1
Orientation
Right and left-handed
Supported Battery Type
AA x 1
Graphite
Microsoft Windows 7 / 8 / 10
AAA type
Installed Qty
2
Required Qty
2
Type: Mouse
Colour: Graphite
Compatibility: PC
Brand: Logitech
