Logitech Slim Folio Pro Keyboard Case for 12.9-inch iPad Pro (3rd generation, 4th generation)
Quicklinx: FTVBWS00 Mfr#: 920-009710
Device Type: iPad Pro
Type: Folio Case with Keyboard
Device Screen Size: 12.9
Colour: Grey
£83.22 ex VAT
£99.86 inc VAT
Turn your iPad Pro into a laptop with one click! Enjoy laptop-like typing anywhere, day or night, with Slim Folio Pro for iPad Pro. Three distinct use modes ensure you can always work at your highest level no matter where you are - a café table, desk, or even your lap.
The light and durable all-in-one case also keeps your device protected from bumps, scratches, and spills. It even features a convenient spot to charge and stow your Apple Pencil (2nd gen).
  • THREE USE MODES
    Slim Folio Pro offers three unique modes to help you accomplish any task more efficiently.   Type Mode: Just dock the keyboard upright and type away. Sketch Mode: Collapse the iPad Pro screen to take notes or draw with Apple Pencil (2nd gen). Read Mode: Fold the keyboard back to read books and articles. When in read mode, the keyboard is temporarily suspended to prevent accidental typing
  • PRO ANYWHERE, DAY OR NIGHT
    Enjoy using your iPad Pro at night or in dim lighting? We do, too. That's why the integrated keyboard comes equipped with backlit keys. Three adjustable levels of brightness ensure you can see what you're doing whether you're in the bedroom, on a plane, or any other low light environment
  • DESIGNED FOR APPLE PENCIL (2ND GEN)
    The Slim Folio Pro case is designed with open sides so you can charge Apple Pencil (2nd gen) with the case on. When you're done drawing, slip Apple Pencil or Logitech Crayon into the magnetic latch to prevent it from being knocked loose during travel
  • START TYPING INSTANTLY
    With a built in auto on/off feature, simply place iPad in type mode to turn the keyboard on. Then remove iPad Pro from the dock to put the keys to sleep. This conserves power so you're able to type longer between charges
Logitech Slim Folio Pro - keyboard and folio case - QWERTY - UK Input Device
Keyboard and folio case
Backlit
3-level
Bluetooth LE
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, volume, search, brightness, screen lock, home screen, battery check button
Protection
Scratch-resistant, spill-resistant, scuff-resistant
28.7 cm x 23 cm x 2.246 cm
707.43 g
Apple 12.9-inch iPad Pro (3rd generation, 4th generation)
Backlit
3-level
Bluetooth LE
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Scissors
Protection
28.7 cm
23 cm
2.246 cm
707.43 g
Carrying Case
Magnetic closure, camera lens cutout, transformable into a stand for typing or viewing video, stylus holder, port cut-outs, AutoSleep, protective corners
USB-C
Rechargeable
Colour: Grey
Brand: Logitech
