Logitech Slim Folio for iPad 10.9-inch (10th Gen) - UK - Oxford Grey
Quicklinx: HYBQWS00 Mfr#: 920-011429
£84.96 ex VAT
£101.95 inc VAT
Now you can enjoy laptop-like typing anywhere you take your iPad (5th, 6th, 7th, 8th, 9th, 10th gen + A16) or iPad Air (3rd gen). This all-in-one case is easy to use and carry around, all while keeping your iPad safe from bumps, scratches, and spills. No matter where you need to get your work done - the backyard, a desk, or even your lap - Slim Folio locks your iPad at an optimal angle for typing, viewing, or sketching.
  • Discover What's Possible
    Full-size keyboard. Light-weight case. Go-anywhere attitude. Meet the astonishingly slim Slim Folio for iPad
  • Type in total comfort
    Enjoy hours of comfortable, flexible typing thanks to a well-spaced edge-to-edge keyboard. Our premium keys have been re-designed for extra comfort, optimal travel, and to deliver the perfect bounce every time you press for fast, accurate typing
  • Secure form-fit protection
    It's not just protection. It's peace of mind. Slim Folio is molded to perfectly fit your iPad, protecting the front, back, and corners from scrapes and bumps. Rest assured your iPad is secure so you can focus on what matters-getting things done
  • Home for your logitech crayon
    A built-in holder for Logitech Crayon or Apple Pencil keeps your digital pencil always within reach so you can easily hand-write notes, sketch drawings, or markup documents directly on iPad
Logitech Slim Folio - keyboard and folio case - QWERTY - UK - oxford grey Input Device
Keyboard and folio case
Bluetooth LE
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, search, mute, brightness, screen lock, play/pause, previous track, next track, home screen, on screen keyboard, volume -, volume +, bluetooth, keyboard battery check
Protection
Scratch protection, bump protection, scrape protection
Oxford grey
Case Material
Plastic, fabric
25.3 cm x 2 cm x 18.67 cm
449 g
1-year warranty
Apple 10.9-inch iPad (10th generation)
Bluetooth LE
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Scissors
Protection
25.3 cm
2 cm
18.67 cm
449 g
Carrying Case
Material
Plastic, fabric
Transformable into a stand for typing or viewing video, water repellent, ports and controls access, protective corners, auto sleep/wake function, Apple pencil holder, 10°-58° adjustable angles
Oxford grey
Limited warranty - 1 year
Brand: Logitech
