Logitech Slim Folio for 10.2-inch iPad (7th generation) - Graphite
Quicklinx: FHZYWS00 Mfr#: 920-009480
Device Type: iPad 8th Gen, iPad 9th Gen, iPad 7th Gen
Type: iPad Case
Device Screen Size: 10.2
Colour: Graphite
15 In Stock
£84.00 ex VAT
£100.80 inc VAT
Slim Folio takes mobile computing to a higher level. Now you can enjoy laptop-like typing anywhere you take your tablet. Its slim, light design makes it a joy to use and carry around, all the while keeping your device safe from bumps, scratches and spills. No matter where you need to get your work done - a café table, a desk or even your lap - Slim Folio locks your tablet at an optimal angle for typing and holds firm on any surface.
  • Discover What's Possible
    Full-size keyboard. Light-weight case. Go-anywhere attitude. Meet the astonishingly slim Slim Folio for iPad
  • Type in total comfort
    Enjoy hours of comfortable, flexible typing thanks to a well-spaced edge-to-edge keyboard. Our premium keys have been re-designed for extra comfort, optimal travel, and to deliver the perfect bounce every time you press for fast, accurate typing
  • Secure form-fit protection
    It's not just protection. It's peace of mind. Slim Folio is molded to perfectly fit your iPad, protecting the front, back, and corners from scrapes and bumps. Rest assured your iPad is secure so you can focus on what matters-getting things done
  • Home for your logitech crayon
    A built-in holder for Logitech Crayon or Apple Pencil keeps your digital pencil always within reach so you can easily hand-write notes, sketch drawings, or markup documents directly on iPad
Logitech Slim Folio - keyboard and folio case - QWERTY - UK - graphite Input Device
Keyboard and folio case
Bluetooth
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Search, mute, play/pause, previous track, next track, home screen, Siri, volume -, volume +, language key
Protection
Scratch-resistant, spill-resistant
Graphite
Case Material
Plastic, fabric
24.8 cm x 2 cm x 18.2 cm
445 g
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
Bluetooth
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Scissors
Protection
24.8 cm
2 cm
18.2 cm
445 g
Carrying Case
Material
Plastic, fabric
Pen holder, sleep/wake function, water repellent
Graphite
Installed Qty
2
Required Qty
2
Device Type: iPad 9th Gen
Device Type: iPad 7th Gen
Type: iPad Case
Colour: Graphite
Brand: Logitech
