Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Logitech Slim Folio - Keyboard and folio case - Bluetooth - UK Englis
Quicklinx: DS95WS00 Mfr#: 920-009024
Slim Folio takes mobile computing to a higher level. Now you can enjoy laptop-like typing anywhere you take your tablet. Its slim, light design makes it a joy to use and carry around, all the while keeping your device safe from bumps, scratches and spills. No matter where you need to get your work done - a café table, a desk or even your lap - Slim Folio locks your tablet at an optimal angle for typing and holds firm on any surface.
  • 3 USE MODES
    Slim Folio offers three unique modes to help you accomplish any task. Type Mode: Just dock the keyboard upright and type away. Sketch Mode: Collapse the iPad screen to take notes or draw with Logitech Crayon . Read Mode: Fold the keyboard back to read books, articles, and more
  • COMFORTABLE LAPTOP-LIKE TYPING
    Enjoy hours of comfortable, flexible typing thanks to large, well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Our premium keyboards are designed to deliver the perfect bounce every time you press a key for fast, accurate typing. With a full row of shortcut keys, you can perform your favorite iOS-specific actions and optimize your productivity
  • CONVENIENTLY INTEGRATED KEYBOARD
    Slim Folio's keyboard is integrated into the case so it won't get lost and is always there when you're ready to type
  • 2 ANGLES FOR TYPING, VIEWING, AND SKETCHING
    In Type Mode, Slim Folio holds your iPad at a 58° angle that's great for getting work done with the keyboard. Collapse the case and Slim Folio will hold your iPad at a comfortable 10° angle that's optimal for viewing your favorite shows, handwriting notes, drawing, and more
  • FRONT AND BACK PROTECTION
    Slim Folio carefully envelopes your iPad for protection against bumps, scratches, and spills. On the inside, a lightweight frame and keyboard module provide structural integrity without weighing down your iPad
  • HOME FOR LOGITECH CRAYON AND OTHER DIGITAL PENCILS
    Sketch, write, then store your Logitech Crayon or Apple Pencil (1st gen) where it won't get lost or in the way. The convenient holder will keep it firmly in place until you're ready to use it next
  • POWER SAVING AUTO ON / OFF
    Slim Folio's auto on-off function turns your iPad on every time you open the folio and puts it back to sleep when you close the case, helping you save precious battery life
  • RELIABLE BLUETOOTH CONNECTION
    Slim Folio uses advanced Bluetooth LE wireless for reliable, energy-efficient connection that won't drop between the iPad and keyboard. Simply set up your connection once, and your keyboard will automatically connect every time you click your iPad into Type Mode
  • 4 YEAR BATTERY LIFE
    Slim Folio uses replaceable coin cell battery to power your keyboard. Thanks to a smart-power management system, use Slim Folio for up to 4 years without needing to replace the batteries
  • 2 YEAR WARRANTY
    We stand behind our products and commitment to excellence. If you need help with a product, our Customer Care team is happy to help. Learn more about our product warranties
Logitech Slim Folio - keyboard and folio case - QWERTY - UK - black Input Device
Bluetooth
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Search, mute, play/pause, previous track, next track, home screen, Siri, volume -, volume +, language key
Protection
Scratch-resistant, spill-resistant
Case Material
Plastic, fabric
24.8 cm x 2 cm x 18.2 cm
445 g
Apple 9.7-inch iPad (5th generation, 6th generation)
Bluetooth
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Scissors
Protection
24.8 cm
2 cm
18.2 cm
445 g
Carrying Case
Material
Plastic, fabric
Pen holder, sleep/wake function, water repellent
Installed Qty
2
Required Qty
2
