Slim Folio takes mobile computing to a higher level. Now you can enjoy laptop-like typing anywhere you take your tablet. Its slim, light design makes it a joy to use and carry around, all the while keeping your device safe from bumps, scratches and spills. No matter where you need to get your work done - a café table, a desk or even your lap - Slim Folio locks your tablet at an optimal angle for typing and holds firm on any surface.
3 USE MODES
Slim Folio offers three unique modes to help you accomplish any task. Type Mode: Just dock the keyboard upright and type away. Sketch Mode: Collapse the iPad screen to take notes or draw with Logitech Crayon . Read Mode: Fold the keyboard back to read books, articles, and more -
COMFORTABLE LAPTOP-LIKE TYPING
Enjoy hours of comfortable, flexible typing thanks to large, well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Our premium keyboards are designed to deliver the perfect bounce every time you press a key for fast, accurate typing. With a full row of shortcut keys, you can perform your favorite iOS-specific actions and optimize your productivity -
CONVENIENTLY INTEGRATED KEYBOARD
Slim Folio's keyboard is integrated into the case so it won't get lost and is always there when you're ready to type -
2 ANGLES FOR TYPING, VIEWING, AND SKETCHING
In Type Mode, Slim Folio holds your iPad at a 58° angle that's great for getting work done with the keyboard. Collapse the case and Slim Folio will hold your iPad at a comfortable 10° angle that's optimal for viewing your favorite shows, handwriting notes, drawing, and more -
FRONT AND BACK PROTECTION
Slim Folio carefully envelopes your iPad for protection against bumps, scratches, and spills. On the inside, a lightweight frame and keyboard module provide structural integrity without weighing down your iPad -
HOME FOR LOGITECH CRAYON AND OTHER DIGITAL PENCILS
Sketch, write, then store your Logitech Crayon or Apple Pencil (1st gen) where it won't get lost or in the way. The convenient holder will keep it firmly in place until you're ready to use it next -
POWER SAVING AUTO ON / OFF
Slim Folio's auto on-off function turns your iPad on every time you open the folio and puts it back to sleep when you close the case, helping you save precious battery life -
RELIABLE BLUETOOTH CONNECTION
Slim Folio uses advanced Bluetooth LE wireless for reliable, energy-efficient connection that won't drop between the iPad and keyboard. Simply set up your connection once, and your keyboard will automatically connect every time you click your iPad into Type Mode -
4 YEAR BATTERY LIFE
Slim Folio uses replaceable coin cell battery to power your keyboard. Thanks to a smart-power management system, use Slim Folio for up to 4 years without needing to replace the batteries -
2 YEAR WARRANTY
We stand behind our products and commitment to excellence. If you need help with a product, our Customer Care team is happy to help. Learn more about our product warranties
 - Logitech Slim Folio - keyboard and folio case - QWERTY - UK - black Input Device
 - Keyboard and folio case
- Interface
 - Bluetooth
- Connectivity Technology
 - Wireless
- Localization and Layout
 - QWERTY UK
- Hot Keys Function
 - Search, mute, play/pause, previous track, next track, home screen, Siri, volume -, volume +, language key
- Protection
 - Scratch-resistant, spill-resistant
 - Black
- Case Material
 - Plastic, fabric
 - 24.8 cm x 2 cm x 18.2 cm
 - 445 g
 - 2-year warranty
- Designed For
 - Apple 9.7-inch iPad (5th generation, 6th generation)
- Interface
 - Bluetooth
 - Wireless
- Hot Keys Function
 - QWERTY UK
- Keyboard Technology
 - Scissors
- Protection
 - 24.8 cm
 - 2 cm
 - 18.2 cm
 - 445 g
Carrying Case
- Material
 - Plastic, fabric
 - Pen holder, sleep/wake function, water repellent
 - Black
- Installed Qty
 - 2
- Required Qty
 - 2
 - Limited warranty - 2 years
- Designed For
