Logitech Slim Combo Keyboard and Folio Case for iPad Pro 10.5" & 12.9" (1st Gen & 2nd Gen)
Quicklinx: D82JWS00 Mfr#: 920-008371
Slim Combo pairs with your tablet for a great experience. Four distinct modes give you amazing versatility, and the smart connector pairs and powers your keyboard in one magical instant.
  • FOUR VERSATILE MODES
    With a detachable keyboard and adjustable kickstand, transform Slim Combo into four use modes for amazing versatility. Type Mode: Click the keyboard into the upright position to type away on notes, emails, and more. View Mode: Set keyboard aside and use the adjustable kickstand to get the perfect angle for viewing movies and shows. FaceTime Mode: Set keyboard aside, pull out the kickstand, and orient vertically to video chat hands-free at the optimal angle. Book Mode: Set keyboard aside and fold the kickstand back to comfortably read books, magazines, PDFs, and more
  • ALL PRO. ALL DAY. ALL NIGHT
    Full-size backlit keys, smart iOS shortcuts and the most laptop-like typing experience on iPad Pro
  • CONNECT LIKE A PRO
    Batteries aren't included, because you'll never need them. Place your iPad Pro into Smart Connector and your keyboard instantly pairs and powers on
  • PRO STYLED PROTECTION
    Keep your iPad protected from scuffs and scratches in an impossibly slim keyboard and case combo for 12.9-inch and 10.5-inch iPad Pro
  • iPad Pro CONTROLS AT YOUR FINGERTIPS
    A full row of iOS shortcuts puts the power of iPad Pro at your fingertips: 1 - Home: Go to home screen 2 - Screen brightness: adjust screen brightness up or down 3 - Search: bring up iOS search field 4 - Virtual Keyboard: shows/hides the virtual keyboard 5 - Backlighting: adjust brightness of keyboard backlighting 6 - Media controls: Back, Play/Pause, Forward 7 - Volume controls: Mute, Volume up, Volume down 8 - Screen on/off - locks iPad Pro screen
  • LEAVE THE KEYBOARD BEHIND
    Whenever you don't need typing, detach the keyboard and enjoy your beautiful iPad Pro screen with nothing standing in the way
  • ALL THE RIGHT ANGLES
    There's a right angle for every situation - and it's not always 90 degrees. Two micro hinges ensure that Slim Combo smoothly reclines within 50 degrees range and stays in place once you've got that perfect setting
  • A HOME FOR Apple Pencil (1ST GEN)
    Apple Pencil (1st gen) brings a whole new creative experience to your iPad Pro, and Slim Combo's Apple Pencil holder makes sure it's always by your side. Slide your Apple Pencil into the holder– where it won't get lost, or in the way
  • FORGET ABOUT CHARGING. FOREVER
    Slim Combo has been designed specifically for the 12.9-inch and 10.5-inch iPad Pro. The keyboard has no charging cable, batteries, or blinking indicator light – getting all of its power directly from iPad Pro. It uses minimum power – 0.3%-2.3% of iPad Pro battery for every hour of typing. Plus, any iOS updates are communicated directly to your keyboard via Smart Connector
  • 2-YEAR WARRANTY
    If you need help with a product, our Customer Care team is happy to help. Learn more about our product warranties
Logitech Slim Combo - keyboard and folio case - QWERTY - UK - black Input Device
Keyboard and folio case
Backlit
Apple Smart connector
Wired
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, volume, search, mute, play/pause, iPad functions, home page
Protection
Spill-resistant
23 cm x 2.6 cm x 31.1 cm
640 g
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
Backlit
Hot Keys Function
QWERTY UK
Palm Rest
Protection
Spill-resistant
23 cm
2.6 cm
31.1 cm
640 g
