Logitech Signature MK650 Combo for Business - Graphite
Quicklinx: HFS9WS00 Mfr#: 920-010999
Recommended Use: Office
Type: Keyboard and Mouse Set
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: ChromeOS, Apple iOS, Mac, Android + 1 more
More than 50 In Stock
£48.56 ex VAT
£58.27 inc VAT
The Signature MK650 Combo for Business is designed for all day comfort. The keyboard's integrated palm rest and familiar keystrokes complement the soft thumb area and rubber side grips of the mouse. All helping to make working hours feel less like work. The Signature MK650 Combo for Business is an easy way to increase employee productivity. The full-sized keyboard includes a numpad and pre-programmed F-Keys to streamline work. And the versatile mouse features a SmartWheel for more efficient scrolling with both line-by-line control and super-fast scrolling.
  • THE ESSENTIAL COMBO
    The wireless upgrade everyone deserves. With advanced technology and designed for comfort. It's the essential wireless combo for improving employee experience
  • A PERFECT PERFORMANCE PAIRING
    From simple set up to precision keystrokes and dual-mode scrolling, this is a combo designed for increased productivity and long hours at the desk
  • UNINTERRUPTED WORKFLOWS
    Worry less about failing batteries and down time. The Signature MK650 Combo for Business includes a AA mouse battery that lasts up to 24 months and two AA batteries for the keyboard which last up to 36 months
  • LOGI OPTIONS+ EFFICIENCY
    Logi Options+ is the next-generation workflow app for increased efficiency, creating shortcuts and customized management of supported mice and keyboards. Predefined settings are optimized for popular software and applications
  • FOR POWER USERS
    Perfect for users who spend long hours at a desk
  • BUILT FOR WORKFLOW
    Integrated palm rest Durable long lasting keys SmartWheel precision scrolling SilentTouch technology Strong adjustable tilt legs Comfort shape mouse with soft thumb area
  • BUILT FOR WORKPLACE
    Logi Bolt USB receiver: Windows , macOS, Linux
  • Logi Bolt Wireless Technology
    Up to 10 meters wireless range, even in congested wireless environments
  • IT Admin Mass-Deployment
    Device firmware updates (DFUs)
  • COMBO FOR COMFORT
  • PRODUCTIVITY X 2
  • BETTER COMPATIBILITY
    The Signature MK650 Combo for Business is compatible with every major operating system and platform, so it's easy to deploy and manage in a multi-platform environment. This can reduce IT help desk headaches and improve employee inefficiency
  • ENTERPRISE-GRADE SECURITY
    The Signature MK650 Combo for Business includes Logi Bolt wireless technology, engineered to conquer IT challenges in the office and when working remotely. Delivering cross-platform compatibility and robust, secure connections-even in congested wireless environments. Fully encrypted and FIPS compliant when paired with the Logi Bolt USB receiver
  • FEATURES THAT DELIVER
    The MK650 Combo for Business was designed to make long hours at work easier. With shortcut keys for increased efficiency and a mouse with programmable buttons, this combo is engineered to keep up with demanding workflows
Logitech Signature MK650 Combo for Business - keyboard and mouse set - QWERTY - UK - graphite Input Device
Keyboard and mouse set
Bluetooth LE
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Qty
6
Hot Keys Function
Calculator, print, Tab, refresh, dictation, Emoji, snip screen, back function, language switch, microphone mute
Numeric Keypad
Pointing Device
Mouse - wireless
Buttons Qty
5
Performance
Realtime sensitivity switching 400 - 4000 dpi
Graphite
Works With Chromebook
Bluetooth LE
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Mouse: 6.1 cm x 10.82 cm x 3.88 cm / 101.4 g , Keyboard: 45.73 cm x 19.35 cm x 2.4 cm / 700.23 g , Wireless receiver: 1.44 cm x 0.61 cm x 1.87 cm / 1.7 g
Wireless
Keyboard Name
Logitech Signature K650 for Business
Hot Keys Qty
6
Hot Keys Function
QWERTY UK
Keyboard Technology
Plunger
Adjustable Height
Palm Rest
Numeric keypad
Pointing Device
Mouse - wireless
Pointing Device Name
Logitech Signature M650 for Business
Buttons Qty
5
Thumb Buttons Qty
2
Movement Resolution
4000 dpi
Batteries:
1
Performance
Supported Battery Type
AA x 1
Graphite
FSC, CarbonNeutral, Works With Chromebook (WWCB) certified
MTBF
150,000 hours
Key Life Span
5 million clicks
Linux, Google Chrome OS, Apple MacOS X 10.10 or later, Android 8.0 (Oreo) or later, Apple iOS 14 or later, Apple iPadOS 14 or later, Windows 10 / 11 or later
AA type
Installed Qty
2
Required Qty
2
Run Time (Up To)
36 months
Shipping Width
52.7 cm
Shipping Depth
20.3 cm
Shipping Height
4.65 cm
Shipping Weight
1.238 kg
Sustainability Information
Product Recycled Content
28 % - post-consumer recycled plastic
Colour: Graphite
Compatibility: Apple iOS
Compatibility: Mac
Compatibility: Android
Compatibility: PC
Brand: Logitech
