The Signature MK650 Combo for Business is designed for all day comfort. The keyboard's integrated palm rest and familiar keystrokes complement the soft thumb area and rubber side grips of the mouse. All helping to make working hours feel less like work. The Signature MK650 Combo for Business is an easy way to increase employee productivity. The full-sized keyboard includes a numpad and pre-programmed F-Keys to streamline work. And the versatile mouse features a SmartWheel for more efficient scrolling with both line-by-line control and super-fast scrolling.
THE ESSENTIAL COMBO
The wireless upgrade everyone deserves. With advanced technology and designed for comfort. It's the essential wireless combo for improving employee experience -
A PERFECT PERFORMANCE PAIRING
From simple set up to precision keystrokes and dual-mode scrolling, this is a combo designed for increased productivity and long hours at the desk -
UNINTERRUPTED WORKFLOWS
Worry less about failing batteries and down time. The Signature MK650 Combo for Business includes a AA mouse battery that lasts up to 24 months and two AA batteries for the keyboard which last up to 36 months -
LOGI OPTIONS+ EFFICIENCY
Logi Options+ is the next-generation workflow app for increased efficiency, creating shortcuts and customized management of supported mice and keyboards. Predefined settings are optimized for popular software and applications -
FOR POWER USERS
Perfect for users who spend long hours at a desk -
BUILT FOR WORKFLOW
Integrated palm rest Durable long lasting keys SmartWheel precision scrolling SilentTouch technology Strong adjustable tilt legs Comfort shape mouse with soft thumb area -
BUILT FOR WORKPLACE
Logi Bolt USB receiver: Windows , macOS, Linux -
Logi Bolt Wireless Technology
Up to 10 meters wireless range, even in congested wireless environments -
IT Admin Mass-Deployment
Device firmware updates (DFUs) -
COMBO FOR COMFORT
The Signature MK650 Combo for Business is designed for all day comfort. The keyboard's integrated palm rest and familiar keystrokes complement the soft thumb area and rubber side grips of the mouse. All helping to make working hours feel less like work -
PRODUCTIVITY X 2
The Signature MK650 Combo for Business is an easy way to increase employee productivity. The full-sized keyboard includes a numpad and pre-programmed F-Keys to streamline work. And the versatile mouse features a SmartWheel for more efficient scrolling with both line-by-line control and super-fast scrolling -
BETTER COMPATIBILITY
The Signature MK650 Combo for Business is compatible with every major operating system and platform, so it's easy to deploy and manage in a multi-platform environment. This can reduce IT help desk headaches and improve employee inefficiency -
ENTERPRISE-GRADE SECURITY
The Signature MK650 Combo for Business includes Logi Bolt wireless technology, engineered to conquer IT challenges in the office and when working remotely. Delivering cross-platform compatibility and robust, secure connections-even in congested wireless environments. Fully encrypted and FIPS compliant when paired with the Logi Bolt USB receiver -
FEATURES THAT DELIVER
The MK650 Combo for Business was designed to make long hours at work easier. With shortcut keys for increased efficiency and a mouse with programmable buttons, this combo is engineered to keep up with demanding workflows
- Logitech Signature MK650 Combo for Business - keyboard and mouse set - QWERTY - UK - graphite Input Device
- Keyboard and mouse set
- Interface
- Bluetooth LE
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Hot Keys Qty
- 6
- Hot Keys Function
- Dictation, Emoji, snip screen, microphone mute, back function, refresh, Tab, print, calculator, language switch
- Numeric Keypad
- Pointing Device
- Mouse - wireless
- Buttons Qty
- 5
- Performance
- Realtime sensitivity switching 400 - 4000 dpi
- Graphite
- Works With Chromebook
- 2-year warranty
- Interface
- Bluetooth LE
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Mouse: 6.1 cm x 10.82 cm x 3.88 cm / 101.4 g , Keyboard: 45.73 cm x 19.35 cm x 2.4 cm / 700.23 g , Wireless receiver: 1.44 cm x 0.61 cm x 1.87 cm / 1.7 g
- Wireless
- Keyboard Name
- Logitech Signature K650 for Business
- Hot Keys Qty
- 6
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Plunger
- Adjustable Height
- Palm Rest
- Numeric keypad
Pointing Device
- Mouse - wireless
- Pointing Device Name
- Logitech Signature M650 for Business
- Buttons Qty
- 5
- Thumb Buttons Qty
- 2
- Movement Resolution
- 4000 dpi
- Batteries:
- 1
- Performance
- Supported Battery Type
- AA x 1
- Graphite
- Works With Chromebook (WWCB) certified, FSC, CarbonNeutral
- MTBF
- 150,000 hours
- Key Life Span
- 5 million clicks
- OS Required
- Windows 10 / 11 or later, Apple MacOS X 10.10 or later, Linux, Google Chrome OS, Apple iPadOS 14 or later, Apple iOS 14 or later, Android 8.0 (Oreo) or later
- AA type
- Installed Qty
- 2
- Required Qty
- 2
- Run Time (Up To)
- 36 months
- Shipping Width
- 52.7 cm
- Shipping Depth
- 20.3 cm
- Shipping Height
- 4.65 cm
- Shipping Weight
- 1.238 kg
Sustainability Information
- Product Recycled Content
- 28 % - post-consumer recycled plastic
- Limited warranty - 2 years
- 0 °C
- 40 °C
