Logitech Signature K650 Wireless Keyboard - QWERTY - Graphite
Quicklinx: H9D9WS00 Mfr#: 920-010918
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Android, PC, Apple iOS, Mac
Hurry, only 1 left in stock!
£35.65 ex VAT
£42.78 inc VAT
Enjoy comfort in every keypress for more satisfying productivity. Signature K650 comes with an integrated soft-touch palm rest and deep-cushioned keys, that give a more satisfying typing experience for long hours at your desk.
  • ALL DAY COMFORT
  • ACHIEVE MORE WITH LESS EFFORT
    Get more done with a full-sized layout on Signature K650 that lets you access all the right shortcut keys and save time with commands like screenshot, mic-mute and unmute, and web navigation
  • WORKS ON MULTIPLE PLATFORMS
    Whatever setup, whatever the platform – Signature K650 works on nearly any OS-Windows, macOS, Linux , ipadOS, iOS, Android. It is also Works With Chromebook certified
  • CONNECT THE WAY YOU LIKE
    Connecting to your devices is a breeze, thanks to wireless connectivity via Bluetooth Low Energy or the included Logi Bolt USB receiver. Get a strong reliable wireless connection from up to 10 meters that lets you stay flexible with where you work while keeping your desk tidy and wire-free
  • RELIABLE AND HASSLE-FREE
    There's no need to worry about your keyboard. Signature K650 will work for as long as you need it to and won't require new batteries for up to 36 months. Its design is also remarkably easy to clean and is spill-resistant
  • SIMPLY BETTER TOGETHER
    Upgrade to better productivity and more flexibility. Combine your Signature K650 with the Signature M650 mouse and download the Logi Options+ Software to discover simple ways to personalize your keyboard and mouse
  • A CHOICE YOU´LL FEEL GOOD ABOUT
    CERTIFIED CARBON NEUTRAL Rest easy knowing that the carbon footprint of your K650 has been reduced to zero. That's because beyond designing for sustainability, we also offset our residual impact by supporting forestry, renewables, and climate-impacted communities that reduce carbon
Logitech Signature K650 - keyboard - QWERTY - UK - graphite Input Device
Keyboard
Bluetooth 5.1
Wireless Receiver
Logitech Logi Bolt USB receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Mute, screenshot, web, multimedia
Protection
Spill-resistant
Numeric Keypad
Graphite
45.731 cm x 19.35 cm x 2.43 cm
707.5 g
Keyboard
Bluetooth 5.1
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Function
QWERTY UK
Adjustable Height
Palm Rest
Protection
Spill-resistant
Numeric keypad
45.731 cm
19.35 cm
2.43 cm
707.5 g
Graphite
Windows 10 / 11 or later, Apple macOS 10.15 or later, Google Chrome OS, Linux, Apple iPadOS 14 or later, Android 8.0 (Oreo) or later, Apple iOS 14 or later
AA type
Installed Qty
2
Required Qty
2
Alkaline
Run Time (Up To)
36 months
Colour: Graphite
Compatibility: PC
Compatibility: Apple iOS
Compatibility: Mac
Brand: Logitech
