Logitech Sight - White
Quicklinx: HFS2WS00 Mfr#: 960-001503
£1,689.12 ex VAT
£2,026.94 inc VAT
AI-powered tabletop camera that delivers a more equitable video conferencing experience.
  • TAKE A SEAT AT THE TABLE
    AI-powered meeting room camera that helps remote attendees feel like they're actually seated at the table
  • FRONT AND CENTER
    Add a tabletop perspective to your front-of-room camera to deliver a better, more inclusive hybrid meeting experience
  • TWO VIEWPOINTS. A BETTER PERSPECTIVE
    A new approach combines Sight at the table with the front-of-room video bar to show the best angle
  • CAPTURE THE ACTION
    Sight uses video and AI to detect and accurately frame participants, with 315° field of view
  • DESIGNED FOR DIFFERENT SPACES
    Created for medium to large collaboration spaces, Sight extends the capabilities of the front-of-room camera to pick up on conversations and nonverbals around the room
  • CLEAR AUDIO. CLEAR VIDEO. CLEAR CONTROLS
    With 4K cameras and 7 beamforming mics, Sight captures conversation and nonverbals clearly. Indicator lights and privacy shade allow for clear signaling and status control
  • CLEAN AND SECURE INSTALL
    Easily install and secure Sight with the included mounts. Keep tables clean and cables plugged in with integrated cable management
  • QUICK TO DEPLOY. SIMPLE TO MANAGE
    SIMPLE TO MANAGE Easily manage your Logitech video collaboration devices with Logitech Sync. Monitor room health, deploy updates, and modify settings all from a single cloud-based platform. And with Sync Insights, you can see how meeting spaces are utilized over time. LEARN MORE ABOUT LOGITECH SYNC
  • OUR COMMITMENT TO SUSTAINABILITY
    Logitech is committed to creating a more sustainable world, using lower carbon materials like post-consumer recycled plastics for our products whenever possible. We are actively working to minimize our environmental footprint and accelerate the pace of social change. LEARN MORE ABOUT LOGITECH'S SUSTAINABILITY INITIATIVES
Logitech Sight - conference camera
Conference camera - fixed
Audio
Yes: built-in seven omni-directional beam-forming microphones
Camera Mount Type
Grommet mount, table mount, tripod mount
White
Wired
Camera
Frame Rate (max)
60 frames per second
Video Modes
4K
Focal Length
1.87 mm
Focus Adjustment
Automatic (min distance 50 cm)
Software Certification
Certified for Microsoft Teams Rooms, Certified for Zoom Rooms, Optimised for Google Meet
Voltage
PoE Plus
Dual cameras, dual lens, intelligent multi-participant framing, AI-powered, up to 2.3 m audio pickup, 315° field of view (using AI), LED indicator, microphone mute control, Acoustic Echo Cancellation (AEC), Voice Activity Detector (VAD), microphone noise suppression technology
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% RH (non-condensing) relative humidity
Conference camera
Audio Support
Camera Mount Type
Wired
Camera
Colour - fixed
Video Modes
4K
Frame Rate (max)
Lens Construction
Focal Length
1.87 mm
Focus Adjustment
Automatic
Min Focus Distance
50 cm
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
97
Diagonal Field of View (degree)
180
Ports
3 x LAN/power - RJ-45
Sight dongle, mic pod dongle, privacy shade, grommet mount, table mount, tripod mount
IEEE 802.3at, CarbonNeutral, IP57
White
Power Requirements
PoE Plus
Windows 10 / 11 or later, Apple MacOS
Relative Humidity (operating)
Brand: Logitech
Price Range Ex VAT: £1500+
