Effortlessly share whiteboards into video meetings with Logitech Scribe, an AI-powered whiteboard camera for Microsoft Teams Rooms, Zoom Rooms, and other leading video conferencing services. With built-in AI and a custom lens, Scribe broadcasts whiteboard content into video meetings with outstanding clarity. Now, even remote participants can have the best seat at the table.
Scribe works with any dry erase marker and all whiteboard surfaces, capturing an area up to 2m W (6') by 1.2m H (4'). Sharing into video meetings is quick and easy, whether using Scribe's wireless share button or your meeting room touch controller, like Logitech Tap.
With a clean wall-mounted design and thoughtful cable management, Scribe installs elegantly and out of the way of meeting collaboration. Together with the whiteboard content camera, Scribe includes a share button, mounting components, power supply, and category cables for deployment at scale.
GET EVERYONE ON BOARD
Effortlessly share whiteboards into video meetings with Logitech Scribe, an AI-powered whiteboard camera for Microsoft Teams Rooms, Zoom Rooms , and other leading video conferencing services -
PERFECT VIEWS, REMOTE OR IN THE ROOM
With built-in AI and a custom lens, Scribe broadcasts whiteboard content into video meetings with outstanding clarity. Now, even remote participants can have the best seat at the table -
SIMPLE TO USE
Scribe's wireless share button makes sharing whiteboards into video meetings quick and easy. You can also initiate sharing with your meeting room touch controller, like Logitech Tap. Share button support may vary by video conferencing service provider. See compatibility page for latest information -
AI-POWERED PERFORMANCE
An AI-powered transparency effect allows participants to see "through" the presenter for an unobstructed view of whiteboard notes and illustrations -
Presenter Removal
Scribe's built-in AI delivers a transparency effect, allowing participants to see "through" the presenter for an unobstructed view of the whiteboard. Actual footage captured by Logitech Scribe -
Content Enhancement
Scribe automatically enhances the color and contrast of dry erase markers, making text and sketches easier to read. Actual footage captured by Logitech Scribe -
Sticky Note Detection
Scribe uses image segmentation to recognize and show other forms of content like sticky notes. Actual footage captured by Logitech Scribe -
PURPOSE-BUILT FOR ROOM SOLUTIONS
Scribe integrates with leading video conferencing room solutions, including Microsoft Teams Rooms and Zoom Rooms. Simply join the meeting and start sharing -
CLEAN, FLEXIBLE INSTALLATION
Wall Mounting Securely mount Scribe to a variety of wall surfaces with the included installation kit. Cable Management Ensure clean, confident installs with cable retention and options to route cabling up, down, or through the wall. Enterprise-Grade Cabling Use the included 10 meters of category cable or supply your own to suit the size and layout of your meeting room -
Wall Mounting
Securely mount Scribe to a variety of wall surfaces with the included installation kit -
Cable Management
Ensure clean, confident installs with cable retention and options to route cabling up, down, or through the wall -
Use the included 10 meters of category cable or supply your own to fit the size and layout of your meeting room. Shown with meeting room computer (not included). See the Setup Guide for a detailed connections overview -
DESIGNED FOR THE MODERN WORKPLACE
Scribe's elegant, minimalist design complements any meeting space -
EMPOWER EDUCATIONAL EQUITY
The right hybrid learning solution helps students see, hear, and understand educators. Now with Scribe, students can stay engaged with whiteboards in the classroom too. Deploy Scribe in your classroom with your Zoom Rooms or Teams Rooms solution, or plug it in to your laptop as a USB device -
SIMPLE TO MANAGE
Easily manage your Logitech video collaboration devices with Logitech Sync. Monitor room health, deploy updates, and modify settings all from a single cloud-based platform. And with Sync Insights, you can see how meeting spaces are utilized over time. LEARN MORE ABOUT LOGITECH SYNC > -
NEXT-LEVEL PEACE OF MIND
Support hybrid workforces and reduce business travel by replacing in-person meetings with video meetings that are as productive as face-to-face. DATASHEET FOR EDUCATION LEARN MORE ABOUT SOLUTIONS FOR HYBRID LEARNING > -
Logitech Select
AN ALL-IN-ONE SERVICE PLAN Logitech Select is a comprehensive service plan that delivers reliability, continuity, and peace of mind for each room you designate. Select provides 24/7 support, a dedicated Customer Success Manager, Available with purchase of a service plan with 50 or more rooms. product replacement, accelerated RMA, onsite spares, Available with purchase of a service plan with 50 or more rooms. and advanced Sync analytics including customizable alerts through ServiceNow integration. Available for users of Logitech Sync. LEARN MORE ABOUT LOGITECH SELECT >
- Logitech Scribe - whiteboard capture camera
- Whiteboard capture camera
- Camera Mount Type
- Wall mount
- 11.9 cm x 59.3 cm x 14.9 cm
- 1.1 kg
- Connectivity Technology
- Wired
- Camera
- Frame Rate (max)
- 15 frames per second
- Video Modes
- 1080p
- Software Certification
- Zoom Certified, Certified for Microsoft Teams
- Cables Included
- 2 - network cable - external - 5 m
- 2-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 10 - 95% relative humidity
- Camera Mount Type
- Wall mount
- Wired
- 11.9 cm
- 59.3 cm
- 14.9 cm
- 1.1 kg
Camera
- Video Modes
- 1080p
- Frame Rate (max)
- Ports
- LAN/power - RJ-45
- Included Accessories
- 2 cable clips, Share Button, dongle transceiver, mounting kit
- Cables Included
- 2 x network cable - external - 5 m
- Cat5e
- Power Device
- Power supply - external AC 120/230 V
- OS Required
- Microsoft Windows, Apple MacOS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 10 - 95%
