Logitech Rally Table Hub
Quicklinx: J67ZWS00 Mfr#: 993-001952
£465.21 ex VAT
£558.25 inc VAT
The Logitech Rally Table Hub is a sophisticated video conferencing device that brings exceptional connectivity and audio/video quality to the meeting room. Designed to cater to the demands of modern conferencing systems, it features a comprehensive range of interfaces including Ethernet, SuperSpeed USB 3.0, USB, USB-C, and HDMI output. This ensures that a variety of devices can be connected seamlessly, making it an ideal choice for professional settings. The inclusion of a 5 m network cable provides the flexibility needed for optimal setup, allowing for the device to be placed in the most suitable position within the room. Furthermore, the Rally Table Hub supports high-quality audio and video transmission, thanks to its HDMI and microphone interfaces, ensuring that every participant can be heard and seen with clarity. With its external power adapter, the device ensures a reliable power supply, ensuring uninterrupted operation during critical meetings. The Logitech Rally Table Hub is not just a piece of hardware; it's a comprehensive solution designed to enhance the efficiency and quality of video conferencing.
  • Efficient connectivity
    The Logitech Rally Table Hub is designed with a variety of interface options, including Ethernet, SuperSpeed USB 3.0, USB, USB-C, and HDMI output. This ensures seamless connection capabilities for a wide range of devices, enhancing the user experience in video conferencing settings.
  • High-quality video and audio support
    Equipped with two 19-pin HDMI Type-A interfaces for HDMI output and support for both audio and video, as well as a dedicated microphone interface, the Logitech Rally Table Hub ensures high-quality audio and video transmission. This feature is crucial for maintaining clear communication in professional video conferencing environments.
  • Extended reach
    With a 5 m network cable, the Logitech Rally Table Hub offers flexibility in setup and placement, allowing for optimal positioning within conference rooms without compromising on connectivity.
Logitech Rally Table Hub - video conferencing device
Video conferencing device
17.6 cm x 13.8 cm x 4 cm
17.6 cm
13.8 cm
4 cm
1 - Ethernet - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x USB , 1 x USB-C , 2 x audio / video - HDMI output - 19 pin HDMI Type A , Microphone
1 x network cable - 5 m
Power adapter - external
Brand: Logitech
