Logitech Rally Mount Kit Rally Ultra-HD Conf Camera
Quicklinx: F9RGWS00 Mfr#: 939-001644
£183.92 ex VAT
£220.70 inc VAT
Logitech Rally Mounting Kit contains camera, speaker, and hub mounts for Logitech Rally, plus cable retainers for secure connections.
  • Invertible camera bracket
    The camera bracket provides flexibility to mount the camera on a wall directly above or below the display for a natural line of sight and eye contact with remote participants. For larger meeting spaces, the bracket can be inverted to position the camera near the ceiling for a more expansive view. A tripod screw and three-point pin system provides stability and helps keep the camera steady when the lens is in motion
  • Low-profile speaker brackets
    Each accessory in the Rally Mounting Kit is tailored to the system component it supports. The two brackets that mount the Rally speakers on either side of the display create a sleek "floating" appearance while enabling the speakers themselves to deliver their full acoustic potential. The result: lifelike conversational sound that helps bring people together even as the enabling technology fades unobtrusively into the background
  • Ventilated brackets for Display Hub and Table Hub
    Two ventilated hub brackets provide versatile mounting options to position the Display Hub and Table Hub on a wall or beneath a table. The brackets are engineered with elevated standoffs to ensure ample air circulation for reliable cooling
  • Cable retention brackets
    Guard against accidental disconnections and related trouble tickets while keeping cables neat and tidy. Each two-piece bracket mounts near the Display Hub and Table Hub to keep the power, A/V, and data cables securely plugged in
Logitech Rally - video conferencing mounting kit
Video conferencing mounting kit
Package Content
Cable
Rally, Rally Plus
Package Content
Cable
Rally, Rally Plus
Brand: Logitech
