Logitech Rally Mic Pod Mount
Quicklinx: FPLSWS00 Mfr#: 952-000002
Hurry, only 3 left in stock!
£63.60 ex VAT
£76.32 inc VAT
Elevate the appearance of meeting rooms equipped with Rally and Rally Plus. With a compact footprint and clever cable management, Mic Pod Mount anchors Rally Mic Pods to the conference table, provides a hidden path for cabling, and organizes excess cable beneath the table.
Mic Pod Mount fits tables up to 50mm (2 in) thick and installs through grommet holes from 25 - 65mm (1 - 2.5 in) in diameter.
With a cable spool to neatly coil excess cabling beneath the table, Mic Pod Mount eliminates unsightly cables above and below the table for a professional look.
  • Perfectly Placed
    Say goodbye to visible cables and wandering mic pods. Mic Pod Mount gives meeting room tables a finished look while making sure that mic pods stay connected, meeting after meeting. Shown with Rally Mic Pod (not included)
  • Fits Most Tables
    Mic Pod Mount anchors mics and routes cables through grommet holes from 25 - 65mm in diameter, and adjusts to tables up to 50mm thick
  • Secures Excess Cabling
    Wrap excess cabling around the cable spool for a meeting room table that looks as organized below as it does from above. Secure the cable spool directly to Mic Pod Mount, or attach to another surface with included mounting hardware
Logitech Rally Mic Pod Mount - microphone desktop mount
Microphone desktop mount
Package Content
Mounting hardware
14.6 cm x 14.6 cm x 9 cm
Matte black
Logitech Rally, Rally Plus
Package Content
Mounting hardware
14.6 cm
14.6 cm
9 cm
Matte black
Placing / Mounting
Under-the-desk
Brand: Logitech
