Logitech Rally Mic Pod Hub for Logitech Rally Mic Pod, Rally, Rally Plus - Graphite
Quicklinx: HZ1NWS00 Mfr#: 939-001647
Hurry, only 2 left in stock!
£198.82 ex VAT
£238.58 inc VAT
Rally Mic Pod Hubs provide installers with the flexibility to customise microphone placement on virtually any conference table. An alternative to daisy-chaining mic pods to one another, Rally Mic Pod Hub provides three connections that support any combination of mic pods or additional hubs. Under-table mounting hardware helps conceal cables for a clean look.
  • YOUR CONFERENCE ROOM. YOUR WAY
    Rally Mic Pod Hubs provide installers with the flexibility to customize microphone placement on virtually any conference table. An alternative to daisy-chaining mic pods to one another, Rally Mic Pod Hub provides three connections that support any combination of mic pods or additional hubs. Under-table mounting hardware helps conceal cables for a clean look
  • Any Table Shape
    Eliminate the back-and-forth cabling on U-shaped or asymmetrical conference tables and add placement flexibility. With three connections for an array of mic pods, Rally Mic Pod Hub cleans up cabling so you can place mic pods within easy reach of meeting room participants
  • Hidden Cabling
    Eliminate cross-table cabling between mic pods by connecting them through grommets to hubs beneath the table. This keeps audio cabling out of sight for a professional appearance
  • Mic Pod Mobility
    Rally Mic Pod Hub lets you connect each mic pod via a single cable. When meeting participants want to move a mic pod to clear table space or to put the mute control within easy reach, they can do so without tugging on neighboring mic pods. Unlike systems that require fixed mic positions, Rally automatically recalibrates the RightSound Mic Matrix 125 times per second for consistent echo cancellation, noise suppression, and beamforming performance
Logitech Rally Mic Pod Hub - microphone interface adapter
Microphone interface adapter
Package Content
Mounting hardware
10.2 cm x 10.2 cm x 1.6 cm
Package Content
Mounting hardware
10.2 cm
10.2 cm
1.6 cm
Placing / Mounting
Under-the-desk
Brand: Logitech
