Logitech Rally Mic Pod Extension Cable - 10m
Quicklinx: GH4KWS00 Mfr#: 952-000047
£170.09 ex VAT
£204.10 inc VAT
Rally Mic Pod Extension Cable adds 10 meters of additional reach to the cabling of Rally Mic Pod or Rally Mic Pod Hub, and is plenum-rated and ECA certified for commercial installation in walls, above ceilings, through raceways, and within standard 19mm conduit.
  • Extended Reach
  • Long Distance Connections
    When used with Rally Bar and Rally Bar Mini, two cables can connect for a total extension of 20 meters
  • From Table Hub to Table's End
    In rooms with Rally or Rally Plus, connect Rally Mic Pod Extension Cable directly to the table hub to accommodate larger tables
  • Integrated Cable Retention
    Rally Mic Pod Extension Cable comes with a cable clip to keep your connections tight and secure
Logitech Rally Mic Pod Extension Cable - microphone extension cable - 10 m
Cable
Microphone extension cable
Length
10 m
Plenum
Rally Mic Pod; Rally Bar, Bar Mini, Plus; Room Solution Large
Cable Type
Microphone extension cable plenum
Length
10 m
Cable clamp
IEC 60332-1-2, ECA
Logicool Rally Mic Pod , Logitech Rally Bar, Bar Mini, Plus , Logitech Room Solution Large
Brand: Logitech
