Logitech Rally Display Hub
Quicklinx: J67YWS00 Mfr#: 993-001951
£465.21 ex VAT
£558.25 inc VAT
The Rally display hub powers up to two speakers, providing rich sound even in larger rooms. A patented suspension system virtually eliminates vibrations that travel through walls, stands, and tables. This improves echo cancellation while keeping video shake-free, even at high volume levels and when zoomed in.
  • Versatile connectivity
    The Logitech Rally Display Hub offers a wide range of connection options with its multiple connector types, including RJ-45 for Ethernet, 9-pin USB Type-B and 24-pin USB-C for high-speed data transfer, as well as 3-pin mini-XLR and 19-pin HDMI Type-A for audio and video output. This versatility ensures seamless integration with various devices and systems.
  • High-quality audio and video
    Equipped with connections for speakers and HDMI output, the Logitech Rally Display Hub enhances any video conferencing setup. It supports SuperSpeed USB 3.0 for superior data transfer rates, ensuring that both audio and video are delivered with exceptional clarity.
  • Easy installation
    With its external power adapter and straightforward interface, setting up the Logitech Rally Display Hub is hassle-free. Its design is optimized for user-friendly operation, making it an ideal choice for both professional and casual settings.
Logitech Rally Display Hub - video conferencing device
Video conferencing device
17.9 cm x 20.6 cm x 4 cm
17.9 cm
20.6 cm
4 cm
1 - Ethernet - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 2 x speakers - 3 pin mini-XLR , 1 x USB-C - 24 pin USB-C , 2 x audio / video - HDMI output - 19 pin HDMI Type A
Power adapter - external
Brand: Logitech
