Logitech Rally Board 65 - Off-White
Quicklinx: J5TRWS00 Mfr#: 960-001731
12 In Stock
£5,878.89 ex VAT
£7,054.66 inc VAT
All-in-one video conferencing that integrates crystal clear video, powerful audio, and AI-driven features.
  • BUILT FOR FLEXIBILITY
    Rally Board 65 is designed for the way you meet. It can be deployed with the camera positioned above or below the screen, ensuring all participants maintain natural eye contact in any space. Shown with Rally Board 65 Cart
  • READY IN NO TIME
    Set up right out of the box in just a few steps and minimize the need for onsite IT support. Included mounts and remote configuration mean you can get Rally Board 65 up and running in minutes
  • Everyone is clearly seen and heard
    Make sure everyone is seen and heard in meeting rooms and open spaces. AI-driven video and audio technologies - RightSight 2 and RightSound 2 - ensure optimal framing and clear sound for every participant
  • DEPTH BLUR
    Provides clear focus and helps eliminate distractions by using a depth-mapping sensor to distinguish between in-focus and out-of-focus areas, delivering a more natural depth effect compared to standard background blur settings. Part of a future software update, follow CollabOS updates for more
  • RightSight 2
    Optimize participant framing and image processing to deliver clear, crisp visuals for more productive person-to-person interactions
  • Grid View
    Enables individual visibility for each participant in a group by splitting and framing them into separate tiles
  • Group View
    Enhances scenarios requiring full group visibility by framing everyone in the room
  • Speaker View
    Facilitates individually focused conversations by framing recent active speakers in the room
  • Camera Zone
    Eliminates distractions by determining who should and should not be framed based on the zone set by an administrator
  • RightSound 2
    Minimizes background noise, reduces reverb, and balances voices, delivering crisp audio and eliminating distracting background noise
  • AI Voice Equalization
    Balances loud, soft, close, and distant voices, ensuring all voices are similar in volume
  • AI Noise Suppression
    Identifies and removes disruptive noises like keyboard clicks and HVAC noise, keeping the focus on the core discussion
  • AI Echo Suppression
    Reduces echoes in larger rooms, ensuring clear and distinct voices
  • Credenza
    Mount Rally Board 65 on a table or credenza with included legs
  • Wall
    Easily mount Rally Board 65 on a wall with a standard VESA mount
  • Cart
    Mount Rally Board 65 on a cart and have the flexibility to move it anywhere it's needed
  • Exceptionally sharp video
    Capture exceptional video quality no matter the space, thanks to the one-inch image sensor and custom-designed lens that enables a wide 115 field of view
  • Designed with privacy in mind
    Feel secure using built-in privacy control - an automatic shutter opens and closes with each meeting, while a status light clearly indicates when the camera and mic are active
  • Touch Display with Two Styluses
    Make virtual collaboration easier with Rally Board 65. The 4K Ultra HD, multi-touch display offers clear, vivid visuals for a more engaging meeting experience. Plus, whiteboarding is made easy with two ready-to-use styluses - no pairing, charging, or batteries required
  • Clear and crisp audio
    Enjoy crystal-clear conversations with Rally Board 65, designed to deliver exceptional audio quality in any space. A powerful speaker system, optimized for open spaces, ensures that everyone can hear, while a far-reaching microphone array with AI-enabled algorithms filters unwanted noises and ensures everyone can be heard
Logitech Rally Board 65 - video conferencing device
Video conferencing device
United Kingdom, Hong Kong, United Arab Emirates
Display
65" 3840 x 2160
Video Input
Digital video camera
Audio Input
Front facing microphone array and rear facing microphone array - beamforming
Audio Output
Speaker(s)
Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth LE
AC 100-240 V
Microsoft Windows 10 / 11, Android
Dimensions & Weight Details
Main system - Width 150 cm Depth 7.6 cm Height 98.9 cm Weight 46 kg , Main system with stand - Width 150 cm Depth 39.5 cm Height 105.1 cm Weight 50 kg
Built-in Devices
Front microphone array, rear microphone array, camera, dual speakers, dual tweeters, Ultra-Sonic emitter, motion sensor, environmental sensor, time-of-flight camera, ambient light sensor, depth sensor
Enclosure Colour
Off-white
Display
Diagonal Size
65"
Native Resolution
3840 x 2160
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Image Contrast Ratio
5000:1
Monitor Features
Touch screen, 20-point IR touch, anti-fingerprint, anti-glare, integrated cable management
Video Input
Digital video camera (colour) - integrated
Digital Video Capture Resolution
3840 x 2160
Video Modes
4K, 1440p, 1080p, 900p, 720p, 480p
Digital Zoom
4
Camera Mechanical Design
Pan / tilt / zoom
Microsoft Teams compatible, Zoom compatible, Google Meet compatible, RightSound 2 technology, RightSight 2 technology, AI noise reduction, motorised privacy shutter, +19° / -19° tilt, motorised tilt, 115.7° field of view (diagonal), 103.3° field of view (horizontal), 60.7° field of view (vertical), time-of-flight sensor, 20.3 megapixels resolution, Depth Blur technology
Video Output
Supported Display Graphics
UHD (3840 x 2160)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Audio Input
Front facing microphone array and rear facing microphone array - integrated
Microphone Operation Mode
Beamforming
Frequency Response
90 - 16000 Hz
Audio Output
Speaker(s)
Output Power / Channel
8 Watt
Total Harmonic Distortion (THD)
<2%
Network adapter
Wireless, wired
Network / Transport Protocol
IPv4, IPv6
FQDN proxy, IP proxy, PAC file proxy, BYOD mode, Public Key Infrastructure (PKI), symmetric key encryption, ARM TrustZone, AES encryption
1 x audio / video - HDMI output , 1 x audio / video - HDMI input , 3 x USB 3.1 - 9 pin USB Type A , 1 x USB-C 3.1 - 24 pin USB-C , 1 x audio - mini-phone 3.5 mm , 1 x network , 1 x network - RJ-45
1 x USB active cable
Mounting Kit
Included
2 styluses, 2 tabletop legs, VESA mount (100mm), cable hook, assembly hardware and tools
AES-256, FSC
Power supply - internal
AC 100-240 V
35 °C
10 - 95%
Brand: Logitech
Price Range Ex VAT: £1500+
