Logitech R500 Laser Presentation Remote - Graphite
Quicklinx: H2V9WS00 Mfr#: 910-005843
£33.09 ex VAT
£39.70 inc VAT
Deliver impactful presentations with the R500s Laser Presentation Remote. Move freely and navigate slides from up to 20 meters away and point out precise areas of focus with the red laser pointer. The R500s is optimized to work with Windows , macOS and leading presentation software.
  • PRESENT EFFORTLESSLY
    Deliver impactful presentations with the R500s Laser Presentation Remote. Move freely and navigate slides from up to 65 feet (20 meters) away – and point out precise areas of focus with the red laser pointer. The R500s is optimized to work with Windows , macOS and leading presentation software
  • SIMPLY PRESENT
    The R500s is a simple, reliable, and hassle-free presentation remote – so you can focus on crushing your delivery
  • INTUITIVE SLIDE NAVIGATION
    The R500s unmistakable three button design means you can navigate your presentation slides with ease and confidence without having to look down to orient your fingers
  • RED LASER POINTER CLASS I
    Point out precise areas of focus in your presentation with an easy-to-use, bright 1 and safe red laser pointer. If you present on TV & LCD screens and need a digital pointer, try the:
  • LOGITECH PRESENTATION APP
    Customize button functions, monitor battery life, and set an on-screen timer from the Logitech Presentation App. Never worry about your computer going to sleep, the app keeps it awake while you present
  • 20-METER OPERATING RANGE
    Connect your R500s to your computer via USB receiver or low energy Bluetooth low energy technology. Then move and present freely from as far as 20 meters away
  • DESIGNED FOR A SECURE GRIP
    The R500s Laser Presentation Remote has been designed to fit snugly into the palm of your hand, and its soft rubber surface and textured buttons allow for a confident grip while presenting
Logitech R500s presentation remote control - graphite
Presentation remote control
Enclosure Colour
Graphite
3.66 cm x 2.47 cm x 12.36 cm
48.4 g
Supported Devices
Personal computer
Wireless Technology
Bluetooth 4.0 LE, 2.4 GHz
Buttons Qty
3 buttons
Max Operating Distance
20 m
1 AAA type
3.66 cm
2.47 cm
12.36 cm
48.4 g
Enclosure Colour
Graphite
Wireless Technology
Supported Devices
Personal computer
Buttons Qty
3 buttons
20 m
Built-in laser pointer, battery level indicator, LED indicator
Operating System
Android 5.0 or later, macOS 10.12, Chrome OS, iOS 8.0 or later, Linux 2.6 or later, MS Windows 7, Windows 10, Windows 8
USB wireless receiver, AAA battery
Laser Class 1, Plug and Play
1 AAA type
Brand: Logitech
